Question about Poulan Garden
Chainsaw will not crank
When i pour gas in the carberator it cranks up, runs, then cuts off. i've cleaned everything i know to clean. what do i do next?
  • Poulan Master
  • 2,239 Answers
This is classic fuel starvation, start, if you have not already done by replacing the fuel filter in the tank, if no better replace the fuel hose in the tank up to the carb, if no better remove the carb, under the pump side carb cover ( normally alluminium ) here you will find the an internal filter, clean or replace, if the pump diaphram curls up then replace, remove the metering side cover of the carb, check the metring lever here moves freely and lifts the needle, when re assembling on the metering side the gasket is used as a spacer so must go on first then the diaphram and cover, on the pump side the diaphram must go against the carb body followed by the gasket and cover, re set the jet screws to one and a quarter turns out from closed, if the saw is still not starting it is most likley a massive air leak, check the manifold between the cylinder and the carb for cracks, splits or loose, replace the crank seals, replace the cylinder base gasket
Posted on Feb 12, 2012
4 Suggested Answers
SOURCE: poulan chainsaw wild thing
Remove the spark plug and squirt a little bit of the fuel from the gas tank into the spark plug hole, replace the spark plug and crank it over several times.
If it runs, or tries to run... that tells you that your engine, ignition system and gasoline are good (or atleast good enough to get it started)
Next check your fuel line and the primer ball. Make sure that when you pump the primer ball that you can see it pumping fuel through the fuel lines in ONE direction only. (It's kind of hard to see, you might have to start the test with empty fuel lines).
If that fails, you need a carb kit because that's where the check valves are. (unless your primer ball is cracked, broken, or clogged)
Next check the metering diafram and needle in the carb. If the diafram is hard (not easily flexible) or if the needle valve is stuck shut the engine will not be able to get the fuel that it needs to run.
If the Needle valve is stuck, just clean it and it'll most likely be fine.
If the diaphram is hardened, you need a carb kit.
If all the above is ok and it still doesn't work... check the gasket at the base of the carb to make sure that the posative pressure pulses from the crankcase are able to make it through the little holes into the carb (that's how it pumps fuel into the carb).
That's pretty much all the easy stuff. Keep in mind that a new carb only costs about $28 at most places.
Posted on May 07, 2009
  • 173 Answers
SOURCE: chainsaw will not idle without cutting off and
Try adjusting the low speed jet.Or rebuild or replace carb.
Posted on Nov 30, 2010
  • 13 Answers
SOURCE: once chainsaw has been cranked
IF PUSHING IN THE CHOKE MEANS SHUTTING THE CHAOKE OFF THEN IT WOULD MEAN THAT YOUR CARBURATOR JETS ARE PROBABLY PLUGGED OR IF YOU HAVE A HUSQVARNA YOU MAY HAVE ROTTED CRACKED RUBBER FUEL LINE.
Posted on Dec 05, 2010
I have apolandpro46cc 20inchchain saw it will start but it cuts off and will not idle
In sequence:
First, if it has a "torch" plug, toss it. Go for BM7A NGK.
See that nothing has come loose- carb & thereabouts.
Dump fuel & put in FRESH mix.
Carb may need adjustment.
See that ignition switch lead and switch are not intermittently shorting.
If all else fails, do a vac/press test- could be crank seals.
More info up front makes it simpler.
Jun 27, 2014 | Poulan Pro Chain Saw 46cc 20"
Gas pouring out of overflow tube, gas in crank case
Definitely a carb. clean problem. Gas is more than 6 months old & has float needle stuck. Clean carbs. & always replace the float needle valve assy\'s & bowl gaskets. There is nothing you can put in the gas tank to clean carb correctly.
Jan 20, 2014 | Yamaha Motorcycles
Will not run
You need to make sure it is mechanicaly ok ( not scuffed the piston ) remove the muffler and check the condition of the piston skirt through the open exhaust port, any sign of damage and the machine will need to come apart.
May 08, 2013 | Echo Garden
Chainsaw stalls
Not sure what to say other than its fuel starvation, if not already done replace the fuel filter in the tank, if no better i would suspect a massive air leak, so replace the crank seals, if there is no primary compression in the crankcsae fuel will not pull through the engine, good luck.
Feb 05, 2013 | Echo CS400 18" Chain Saw
Briggs & Stratton 4 cycle Lawnmower engine no fuel from carberator. Fuel is being supplied to carberator but only runs when starting fluid is used. Gas is new. What's clogged?
the float may be gummed up. or the needle is plugged up.
you need to clean the carburetor, old gas left in the carburetor turns
into shellac and gums up in side. you need to take it apart and clean it.
Jun 05, 2012 | Garden
Engine stalled out,would not start, pour gas in carb,cranks,keeps running,until idle falls below 12to1500rpm,than stalls out again and will not crank,repeat gas or starting fluid in carb,cranks runs and...
This truck is fuel injected, the problem sounds like a weak fuelpump, it runs when you pour gas into it until that gas runs out, the first thing is to test the fuel preasure, if the pump is weak it may run with gas poured into it but wont idle, also a common problem is the coolant temp sensor and the ground wires to thermostat housing bolt but i wont bet its the pump inside the fuel tank, if you put a fuel gauge on it there should be at least 55-61 psi if its a few pounds lower it can cause problems, you have everything else and it runs with gas poured so its a fuel problem check the preasure, theres a valve up top on the fuel line to connect a fuel gauge to it, start there hope this is helpful.
Dec 27, 2010 | 1993 Chevrolet C1500
Chainsaw dies out when gas is pressed to full throtle
Carb needs teardown and cleaning. May be a stuck float or clogged jet.
Spraycleaner just wont cut it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Echo CS-440 Chainsaw. Was cutting firewood, saw running fine until I refilled the gas tank. The gas was a few months old but looked clean and smelled OK. But after I filled the tank could not get the...
unleaded fuel is notorious for going stale,and it can leave a resinous coating in the carb-try running the saw on half choke with new gas and less oil eg 50 to 1 for say ten minutes,this should clear the gunk out-if this does not work,you have two choices-strip and clean the carb,or adjust the H (high) scew on the carb anti-clockwise by a quarter turn a time till it revs out full bore-good idea to remove the chain and wear ear defenders when adjusting-and always use a chainsaw at its max rpm,or you run the risk of "kickback"
Feb 25, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
1989 jeep cherokee 4.0 cuts without warning or when you let off gas pedal
check the crank position sensor and the throttle position sensor
Oct 15, 2009 | 1989 Jeep Cherokee
Won't continue running
This unit has a fuel solenoid on the carberator, which opens to allow fuel to the carberator. Check to see if this solenoid opens while cranking.
May 07, 2009 | Electrical Supplies
Garden Logo
448 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
