Question about Maytag MEDE300V Dryer
Dryer wont start says check lint trap Model MED300VWO
Check lint trap light blinks and dryer won't start, I cleaned lint trap all the way out the exhaust line including the impeller. Also replaced the metal strips on lint trap cover with new ones
4 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: Maytag Dryer not working properly after cleaning lint trap.
where does the noise sound like its coming from??
Posted on Oct 08, 2007
  • 659 Answers
SOURCE: My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Posted on Apr 08, 2009
rylee_smith
  • 8619 Answers
SOURCE: my check lint filter light is on, lint filter has
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the sensor that has gone bad and needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Amana Electric Dryer
You lucked out there but better replace that start switch because it will do it again just when you don't want it tol
Feb 21, 2012 | General Electric Dryers
My dryer won't work! The light works and the lint
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Kenmore Dryers
My dryer has worked GREAT...today lights blinking check filter..I thoroughly cleaned the lint filter and cleaned behind and IN lint fliter trap and it still is blinking and WILL NOT let me dry anything....
No there is only 1 filter,typically once a error code is display unlit its clered it wont clear itself.refer to your owners manual to see how to clear the code
Aug 06, 2011 | Dryers
What to Do If a Dryer Won't Heat? Brand name Inglis, It's only 2yrs old, While I'm using stop for a while then when I start again the timer is done my clothes is not dry & it's cold. We...
If yourdryer is not heating, check your dryer's venting. First thing to check is to see if you aregetting air flow to the outside through your vent hood. Next, check your voltage to see if you aregetting 220 volts to your outlet. Youcan do this by taking a volt meter set at 250 volts. Take the red leg of the volt meter to the oneside and the black leg to the other side. If the volt reader reads 220 then you are getting the propervoltage. Finally, if you are getting 220volts then it is your dryer heating elements. On a 220 volt for the dryer one leg is for the motor and leg is for theelement. If you are getting 220 volt thenit is your heating elements that are bad.
May 11, 2011 | Dryers
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
My dryer's check lint screen light will not go off. I have cleaned the screen and vacuumed out the lint trap and it still will not reset.
Hi
Thanks
Rylee
Jul 28, 2010 | Kitchen Ranges
Hello-I have the Kenmore Electric Dryer model 110-66842501 series 80. Started the dryer and noticed a burning smell & the dryer was unusually warm to the touch. Now there is no heat. Drum turns...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 12, 2010 | Dryers
Maytag MEDE300V Dryer Logo
42 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
