Whirlpool ET0WSRXML Top Freezer Refrigerator
Problem for Whirlpool ET0WSRXML Top Freezer Refrigerator
Model ET14NKXEW00 Top freezer 1996 model Whirlpool refrigerator
By teeth744 on Oct 24, 2008
Water leaks down into the refrigerator from somewhere and it spills out on the floor. We do not have an icemaker or a water source hooked to the refrigerator, so the water must be condesation. Someone suggested something wrong with the automatic defroster? This has been going on to some degree for a year or more, but not constantly. Should I just get a new refrigerator? The freezer and refrigerator both cool well.
Same Problem
Mar 11, 2009
-   I CAN'T FIND THE DRAIN HOSE TO CHECK IF IT IS PLUGGED. HOW DO I FIND IT?-   Guest
Best Solution
posted on Nov 20, 2008
Helpful)
oscarn
Rank: Wiz
Rating: 75%, 68 votes
Water from the melted evaporator frost is normally drained down to a pan mounted on the compressor . The heat from the compressor is normally enough to vaporize this water. Sometimes the evaporation may be reduced due to- high humidity (in the kitchen). Try keeping the exhaust fan on for a while. Also check if the drain line is blocked or shifted out of the drain pan.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool ET0WSRXML Top
Questions and Unsolved Problems for Whirlpool ET0WSRXML Top
Do you recommend Whirlpool ET0WSRXML Top Freezer Refrigerator?
Answer
Answer
water keeps pooling up in crisper draws. It is leaking from somewhere but I can't find it. The coil... (More)
Answer
ice maker/water dispenser does not work when a glass or cup pushes on the switch
Answer
there is water running inside my fridge. how can this be solved?
Answer
the ice tray does not fill up with water. I changed the valve at the bottom of the frig. but it... (More)
Answer
the coolent line, in freezer turned cherry red hot.
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
