My monitor heater 441 is not maintaining temp. properly,
It reaches the set temp. 68 degrees then kicks off when it kicks back on the temp drops to 60 degrees before it starts to heat back up, it runs but is not getting hot very fast.
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
SOURCE: GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Posted on Sep 18, 2007
SOURCE: Hot tub won't stay at set temperature
I have a 2002 Infinity 6 man spa that I just got from a friend. I am also an Electrician. I had to replace the Spa pack because it wasn't working. Once I replaced the Spa Pack and used the tub it got up to temp no problem but once I got in the temperature slowly dropped and it couldn't keep up. After some research and discussion with a pool tech I found out that there is a jumper on some spa packs. It is a LC (low current) / HC (high current) jumper. It limits the current (amperage) that your tub draws. If you are running it on the LC setting it keeps the tub at low current by not running the heater when the jets are on. (this way it keeps the current low by running one only at a time) If you set it for HC it will allow high current to be drawn and let the heater and the jets be on at the same time. On my spa pack it is P26 Jumper. I have found it is also listed as Jumper 4 on some spa packs. the jumpers are located in the lower right of the circuit board. Make sure you shut off the power to the tub and know what you're doing before you attempt changes. you can also google "Gecko Spa Pack Service Manual" and you will find the manual for your tubs spa pack. Good luck.
Posted on Dec 18, 2008
mastatech
  • 478 Answers
SOURCE: GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Posted on Mar 14, 2009
  • 22 Answers
SOURCE: staying at 96
Check where the temp sense line plugs into the circuit board. Make sure it is snugg. (unplug the unit first)
Check that the sense line is away from the heat source.
Make sure there is no exposed wire on the sense line anywhere.
If you know someone else with a toyo, borrow their sense line and see if the prob stays. If it does, it could be a circuit board prob.
Posted on Oct 23, 2009
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
Goodman GKS9. I have this unit in a condo that I only use sparingly in the winter. I keep the dual thermostats both at 57 and it maintains that tempeature. The problem is that when the thermostat is raised...
The presure switch is breaking down try taking the tubes off and blowing down the switch , or take a small drill bit and clean inside the connections to the pressure switch some times this becomes blocked .
Jan 16, 2012 | Goodman Heating & Cooling
I turned my thermostat down this morning to 68 degrees. I came back about 2 hours later to increase the temp to 70 degrees but when I push the ^ arrow instead of showing the increase to 70 it just flashes...
Since it's within 2 degrees of your setting it could be one of two things. Most furnaces run longer (pass your setting) to maintain the setting you made. Which really not a problem. However, your thermostat may need calibrating. To test this theory, place a regular wall thermometer next to your furnace's thermostat and see if the two temps match when the furnace cuts on and then when it cuts off.
If the temps are both the same, the furnace thermostat is fine.
If you're turning it down to 68, because no one will be at home during the day, just set it 2 degrees cooler than 68 degrees. You will then wind up with 68 degrees.
Feb 09, 2011 | Heating & Cooling
When i change the temperature to make it hotter, the screen blinks then goes back to being 30 degrees colder. Is my heater ignoring my request because it never reaches the temperature i want it to. it...
First you have to understand in thermostat there are Fahrenheit & Centigrade degree. If Centigrade between 16 to 30 and if it is Fahrenheit 60 to 86.
If you press the symbol ther> and > (or) ther- and ther+ at a time degree will change.
Now you set your temp +10 degree from your room temp and also keep "heat" mode.
Dec 14, 2010 | Heating & Cooling
Temp is set at 68 degrees ,monitor is still running at 84 degrees in the room. what can be wrong.
Do you have the economy plus button light on? When you press the economy plus, the heater will run until it is 12 degrees above what you have it set on before it will cut off. If this is not the case then you may be looking at a circuit board issue.
Nov 06, 2010 | Heating & Cooling
Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Jan 09, 2010 | Heating & Cooling
I have to play with thermostat to get my heating system on
You did not make it clear if the thermostat is a programmable unit or not. I am wondering if the thermostat is not set on the correct heat anticipation setting. A heat anticipater is a small heater that helps the thermostat turn off before it over shoots the desired temperature setting. If the thermostat is set for a 5 degree setting, it will turn off at 63 degrees if set at 68. If the anticipater was set at 1 or 2 degrees, it will shut off the heater at 66 or 67. Newer thermostats will only allow the thermostat to cycle 6 times per hour so if you never reach the desired temp, you have to wait 10 minutes before it will allow a call for heat. Check the installation instructions to see if there is a setting where you can get the anticipator temperature closer to your set temp. Good luck.
Dec 11, 2009 | Goodman Heating & Cooling
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Forced Hot Air Heating system doesn't maintain thermostat setting
It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
Good luck, hope this helps.
Matt
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Samsung 8000 btu window air conditioner
Air conditioners rely on a difference in pressure between the "high side" and "low side" in order to perform. Of course, a/c's are designed to work in the heat. Having a cooler outdoor temp of 70 degrees probably is not sufficient to maintain adequate head pressure and will result in reduced cooling capacity. Also, since it was 68 in the morning in the room, it is possible that the indoor coil began to freeze up. Basically, you have a cold coil that you keep warm by moving air over it. If the air doesn't have enough specific heat (what your thermometer measures) it can allow the coil to get colder than 32 degrees and the condensate from all of your humidity will begin to freeze on the coil. My recommendation would be to check the a/c on a day that is 80+ degrees. If you have an avarage indoor temp of 70 degrees you should be able to look for the air coming out to be approximately 20-25 degrees colder than the air being sucked in.
Jun 10, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
