Question about Sony KDF-E50A10 50 in. LCD HDTV
I found the switch if it still not working do I need to change the whole chip?
I have the 3 red blinking light I found the switch and pushed it down. But I still get the three red light. Do I need to buy a new chip????
    Top Expert:
  • Sony Master
  • 74,383 Answers
Hello
Just unplug the TV from AC mains wall socket. Replug it after 2 minutes or so, and see whether it helps you. This must reset all the settings to your set, and must switch On.
If not the set need service. There is some unpredictable fault to its main board A through check should be done. In most cases, ther is no repair to the main board,a s it is assembled with sophistcated automated machines. 90% of the components on it will be of micro sizes, and cannot be replaced by ordinary hand soldering techniques.
Posted on Feb 12, 2012
My playstation won't switch on. The red light light flashes and whenever i try to switch it on it goes back to the red flashing light.
hey there alison
If you have the red blinking light then you have the RED light of death AKA the RLOD.
The light is a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the RLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click Here For The PS3 Manual which has helped so many people like you.
Good luck
Best regards
Peter
Aug 29, 2011 | Sony Playstation 3 (PS3) Console
Red flashing light
Hello there jpalmer
Good luck
Best regards
Peter
Aug 27, 2011 | Sony Playstation 3 (PS3) Console
I have a solid red light,push on button,light goes green for two seconds then blue light comes on briefly,then orange light briefly then flashing red.....Help
Hello there peter
Good luck
Best regards
Peter
Aug 19, 2011 | Sony Playstation 3 (PS3) Console
My PS3 80Gb shows the red standby light as normal. When I push the power button, I hear one beep, as the light go from red, to green, to off, and then finally back to red again. If I push the eject button...
Does the lights blink red? If so, You have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself as some would suggest.You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED*
IS THERE A DISC STUCK INSIDE?
If you have a unit that is not backwards compatible, any non 60g or 80g then you can retrieve your disc.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
You will have to have the system repaired so that you can eject the disc the normal way. If the technician cannot repair your system, simply ask him to remove your disc.
Feb 03, 2011 | Sony PlayStation® 3 (80GB) Console
Red light blinks 3 times
Lamp door is not installed correctly (not pushing on safety switch). Try to reinstall it.
Or safety switch failed. In this case you need take whole TV apart in order to replace it.
Mar 09, 2010 | Sony Grand WEGA KF50WE620 Television
Ps3 comes on light changes to amber then blinking red wont stay on longer than 3 seconds Same problem, it tries to start, makes a litle wizing noise and stops, the red light blinks until you close it at...
You need a screwdriver, a heat gun, arctic silver compound, lots of patience.
Dismantle your ps3 down to the motherboard. Clean off the compound on the Graphics chips with isopropyl alcohol. Set your heat gun to around 700*F. Apply hot air to each of the Graphics chips, 1" away, in a swirling motion for 15-17 seconds each on one side. Let cool down for 20min. DO NOT MOVE THE BOARD. Repeat for the other side. Let cool down for 20min. DO NOT MOVE THE BOARD. Apply new compound to the graphics chips with Arctic Silver. Put the PS3 back together and it should work. It worked for me!
May 26, 2009 | Sony Playstation 3 (PS3) Console
Blinking red light
Mar 12, 2009 | Sony PlayStation® 3 (60 GB) Console
While charging my O2 atom exec, the LED (Flash light) does not glow red ?
I have the same problem. What I did several time is to actually shut down the phone, remove the battery and leave it like that for several hours (3 to 4 hours). Then, I put the battery back in the phone, and it would charge again. However, due to the long time with no battery, the phone's clock would be reset to January 2007.
I found no other work around right now. However, I have to do this more and more often, almost once a week ...
Mar 21, 2008 | O2 Xda Atom Exec Smartphone
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I need a code for the TV
Check out the Remotes in Radio shack. 2 models support durabrand. I purchased the "3 in 1 easy to use" universal remote for $5.99 and used the codes for the Durabrand and it worked perfectly.
Nov 26, 2007 | Durabrand DWT1304 13" TV
Sony KDF-E50A10 50 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
