Question about Juki HLZ 35Z Sewing Machine
Picking up bobbin thread
I just bought a Juki HZL-35Z and this is my first project with this machine. Suddenly, the machine stoped to sew and I found out the needle is not pcking the bobbin thread. Help!!!! I need to finish this today!!! Grrrrrr
sew dutch
  • 24 Answers
SOURCE: Juki HZL-E61: cannot get tension right on straight stitch
Loops on the bottom of the fabric direct the problem to the top thread. Rethread again and make sure the thread goes through the tension discs. Lift the foot, because this is what opens the discs. When sewing and the foot is down, the discs should be closed and thus giving the upper thread the tension it needs.
Posted on May 25, 2009
  • 3 Answers
SOURCE: double needle use on Juki HZL-E80
if the machine regular needle threads front to back NOT side to side, you can use a double needle. simply pass both threads thru all the same slots (thread one at a time so they don't get twisted up) then just before the needles, leave one out of the thread guide just above the needle. you may have to loosen the top tension SLIGHTLY, like a half number. and do NOT use a zig zag stitch without first hand cranking it thru the cycle to be sure the needles clear, or you'll make a 5.00 mistake (the cost of the double needles!)
Posted on Jun 16, 2009
  • 161 Answers
SOURCE: I recently purchased a Juki
perhaps you have the wrong needle or its not in the proper position?
Posted on Sep 12, 2010
SOURCE: Juki DDL-8700--top & bobbin thread won't hold together for stitch
What bobbins do I use on a Juki DDL-8300
Posted on Mar 11, 2011
SOURCE: I have a Juki DU
Be sure you have the proper needle - it is longer than standard needles, plus be sure that you put the needle in from left to right - not...front to back.
Posted on Apr 26, 2011
Hi, my wife has just bought a juki hzl-f600 machine and almost immediately the top thread cannot pick up the bobbin and the thread gets caught when sewing.
If this is a brand new machine, it should be covered under warranty. You can take it back to the vendor and ask them to replace it since it is a defective unit.
Apr 01, 2017 | Juki Sewing Machines
My sewing machine is jammed how can i solve it
Loosen the needle, try to remove the presser foot. Then try to remove the bobbin case from the machine.
Otherwise, if it is jammed with a wad of thread, you can try using very small scissors and tweezers to remove the pieces of thread.
Jan 21, 2017 | Juki Sewing Machines
Juki HZL-F series bottom bobbin thread is not picked up and will not sew when start button is pushed.
Try a brand new needle. If that doesn't work, most likely the machine is out of time.
Nov 14, 2016 | Juki Sewing Machines
Juki hzl 600f. Why isn't thread cutter working?
the thread cutter may need to be checked to see if it need to be replaced,,
try a new needle-- one for the fabric being sewed
make sure the top thread is not coming off the thread take up lever
make sure the bobbin is turned the right way in the bobbin case
could also have a timing problem
Mar 06, 2016 | Sewing Machines
I have a Juki HZL-K85. I changed to a heavier thread for outdoor material, the thread bunched up and the machine made a crunch noise. I got the fabric free, but now the bobbin thread is not being picked...
Check the needle to see if it is bent. If not then check the needle to hook timing. Turn the hand wheel until the needle is at it's lowest position. Start to bring the needle upward. As the needle gets to the edge of the hook/bobbin race the point of the hook should pass slightly above and behind the needle. If it isn't the timing is out. I would suggest bringing it to a trusted sewing machine repair person to reset the hook timing and check for any other damage.
Sep 14, 2013 | Janome 1600P-DB Mechanical Sewing Machine
My juki hzl35z will not pick up the bobbin thread suddenly! Help!
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Apr 26, 2012 | Juki HZL35Z Mechanical Sewing Machine
I need to know how and where to oil my juki HZL-E80 sewing machine
your machine is not a self oiling machine, you should put the oil on the needle bar, and to the bobbin.
Dec 30, 2009 | Juki HZL-E80 Computerized Sewing Machine
May 25, 2009 | Juki HZL-E61 Computerized Sewing Machine
Thread continues to jam
Hi, my wife and I just bought a Juki HZL-E80... I love the machine. I had a problem like you discribe...This problem can come from two sources...one the bobin has been installed improperly. ...or been wound incorrectly by not haveing adjusted the Bobbin tension ...I did the tension adjustment with the screwdriver supplied with the machine accessories. Also...this is a biggie...the auto matic needle threader works great...but I discovered that when I preformed this function..that I over looked the thread holder that keeps the thread even with the needle....so, the solution is to thread the needle then be sure to check that the thread coming down from the spool is placed behind the little wire holder above the needle...I hope this helps you ...because it is a wonderful machine.....Bill & Donna Bramble...Caldwell Idaho...
May 15, 2009 | Juki HZL-E80 Computerized Sewing Machine
Juki HLZ 35Z Sewing Machine Logo
48 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
