Question about Honeywell Vista 20P Alarm System Kit with 6160 Keypad V20PACK 1
Programming vista 20p for 5882 receiver
I have a sa 5882-3ENH RF Receiver and i do not know how to programm my vista 20p for the panel to see it i used *29 but the serial number the way it is showing do not match with the one i have thank for your attention to my problem
    Problem Solver:
  • 6 Answers
Is this the only wireless zone you are adding to the system? Is the Vista20P programmed for other hard wired zones?
Posted on Feb 20, 2012
Vista 20p momentary sounds alarm when system is armed why is this?
It can be disable in installer level programming. It is called confirmation of arming ding. It is so you know that your system is arming when you use you keyfob from outside of your house.
Mar 04, 2014 | Honeywell Ademco 6160 Alpha Keypad Vista...
Tip
How to record a program you are watching on your cable satellite receiver.
Hello,<br /><br />Most of the time we watch TV programs with our cable satellite receiver/decoder. And sometimes we would love to record these programs so that we can watch them again. You can learn how to record your TV program while you watching a TV program. <br /><br />All you will be needing is a DVD recorder or VCR (Video cassette Recorder). It all depends on the one you prefer.<br /><br />There are two methods of doing this connection. 1. is RF connection and the other is RCA. But I will start with the RF connection method;<br /><br />This is how is works. Get a RF cord, check the back of your TV, you would see RF in, connect the RF into TV in, then connect the other part to RF Out at the back of the Cassette or DVD Recorder.<br /><br />Turn the Cassette or DVD Recorder and the TV on. Go to Channel 1 or any channel on the TV, search the TV stations automatically or manually in order to get a display of the Cassette or DVD Recorder on the TV. To easily get the Cassette or DVD Recorder's station, play a movie on the Cassette or DVD Recorder while you search for the station. Once you see the display of the movie on your TV, you would easily know that that's the Cassette or DVD Recorder station. <br /><br />Once you have gotten a display from the Cassette or DVD Recorder, save the channel on the TV.<br /><br />Then get another RF cord, connect it to "RF out" at the back of the Satellite/cable decoder/receiver and the other part to "RF in" at the back of the Cassette or DVD Recorder.<br /><br />Now with the Satellite/cable decoder/receiver turned on and the Cassette or DVD Recorder also turned on, press the Cassette or DVD Recorder's channel, you should find search. Scan for channel/stations on the Cassette or DVD Recorder just like you did on the TV and you will find a display of the Satellite/cable decoder/receiver showing on the TV via the Cassette or DVD Recorder. Note that on some Cassette or DVD Recorder, you will have to select "Source" to RF before you can get a display of the channel.<br /><br />Now since the Satellite/cable decoder/receiver program is now showing via the Satellite/cable decoder/receiver, insert a black disc or cassette into the Recoder and press record. The Satellite/cable decoder/receiver programs showing on the TV via the player will be recorded and that would be all.<br /><br />For some recorders that has internal hard drive, you can just press record without inserting a blank disc......<br /><br />USING RCA CONNECTION METHOD.<br /><br />You could also achieve this by using a RCA (yellow, red and white cord).<br /><br />The connection procedure is the same with the RF explained above.<br /><br />Connect the Recorder to the TV. That is, from "Video and audio Out" of the recorder to "video and audio in" of the TV accordingly. Press AV or source on the TV to confirm that there is a display from the recorder on the TV.<br /><br />Now connect the RCA cord to "OUT" from the Satellite/cable decoder/receiver to "IN" at the back of the Recorder.<br /><br />Then, press source on the recorder to "INPUT" (RCA) and the Satellite/cable decoder/receiver's program will automatically display on the TV. <br /><br />While the Program is being displayed on the TV via the recoder, insert a blank disc and press record on the player and it will automatically start recording. You will see the record or record symbol while the recoding is in progress.<br /><br />I hope you understand the above. Please follow steps closely and you won't have any problems.<br /><br />Good luck.
on Mar 09, 2011 | Televison & Video
Can't access installer code honeywell vista 20p
Power down the panel, remove the battery. Hold down the * and # while re-powering the panel. It will jump right into programming. Release the *and # button and proceed with programming.
Apr 07, 2013 | Honeywell Ademco 6160 Alpha Keypad Vista...
Honeywell vista 20p FC error code no monitor service beeping every 30 sec. need help how to stop beeping
If the keypad displays FC, that means that it is programmed to send alarms to a central station and a phone line isn't connected to the control panel. If you do not subscribe to monitoring services, it will have to be re-programmed. I can do that for you over the telephone if needed.
Thanx Mark Garrett
Aug 21, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
I have an ademco 20p system. Never used it until after the breakin! Any way, now programed but, I get a check 09 signal that flashes. Won't allow me to arm the system
Check 09 indicates a problem with an expansion device, either a hardwired expansion board (4219 or 4229) or wireless (RF) receiver (5881 or 5883 in Canada) or RF receiver integrated in one of your keypads. What expansion device(s) do you have?
Aug 27, 2010 | Honeywell 5804 Ademco Wireless Security...
Can't program rc65 directv remote to control hr21-700 receiver
I believe the codes 00001 and 00002 are valid for all DirectTV receivers.
Instructions for entering the codes are here.
Instructions for searching for the proper code if those two don't work, or for other devices, are here.
If you'd like a digital manual for your RC65, click here.
I hope that helps.
Jan 25, 2010 | Directv HR21-700 DTV Receiver
How do you enable the visible exit countdown on the vista series?
Get into programming then enter # 197. If you get a zero and a beep, enter *1971 then get out of programming. This will work on vista-15p, vista-15psia, vista-20p, and vista-20psia panels
Jan 02, 2010 | Honeywell 5804 Ademco Wireless Security...
Direct TV TC64R remote does not work in RF mode with RCA DRD486RH
The DRD486RH is both IR and RF capable but the remote that you have is obsolete.
Mar 04, 2017 | Televison & Video
I have tuned in my video to my tv but I cannot get the tv station
I had a similar problem. After a nearby lightning strike I lost video to the TV. When the SA-HE100 source switch was set to DVD or TV I lost the TV picture. In my system configuration I send composite video (yellow jacks) to the SA-HE100 from the DVD player, VCR and satellite receiver. From the "TV Monitor Out" jack (yellow jack) the video goes to an RF modulator then is sent to the TV as RF channel 3. At first it seemed the modulator was defective but plugging in another identical modulator damaged the second unit also. This made me look at the amp as the culprit. Curiously, the amp would pass through VCR video without a problem but I didn't know it because of the damaged RF modulator. Whenever the amp source switch was set to DVD or TV the amp would put -4.75V DC on the "TV Monitor Out" jack thereby damaging the connected RF modulator. The repair is relatively simple. The only special skill required is you will need to be able to desolder a 14 pin DIP IC. The damaged component on my amp was IC364 mounted on the board that holds the yellow video jacks. The IC is a JRC 2279D, a 3 input/2 output video switch available from Digikey p/n NJM2279D-ND, $1.50 each.
May 09, 2009 | Panasonic SA-HE100 Receiver
Honeywell Vista 20P Alarm System Kit with 6160 Keypad  V20PACK 1 Logo
535 people viewed this question
Top Honeywell Home Security Experts
Steve
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
