Question about LG WM2688HWM TROMM SteamWasher
How do I replace the thermostat on a WM2688HWM
LG TROMM WM2688HWM no power unless i manually rotate the drum
You have to check and replace the motor capacitor. There would a starting capacitor attache to motor. You have to replace that.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 02, 2016 | LG WM2688HWM TROMM SteamWasher
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
Mold substance found in rubber ring of a front load washer WM2688HWM
comes from the powder/liquid soap use..no solutions,,sorry,, claen after use allways dry
Jun 21, 2010 | LG WM2688HWM TROMM SteamWasher
How to clean pump filter on lg wm2688hwm
No, probably have a bad water pump, very common for this washer. I would pull the washer out, lean it against your wall, brace or block it up so you can crawl under it. You will see where the drain hose comes out of the bottom left of the drum and enters the drain filter. Remove the hoses and check for debris or clothes in the hoses or where the drum outlet is. If no restrictions then replace your water pump. Good Luck, Appliance Specialists
Dec 20, 2009 | LG WM2688HWM TROMM SteamWasher
Cold water keeps running making door open and flood
check for a sticking/leaking cold water inlet solenoid valve at back of the washer, very easy to replace.
Sep 19, 2009 | LG WM2688HWM TROMM SteamWasher
ERROR NOT DRAINING
the filter is located right after you open the drain cover on the bottom of the washer it's a hard plastic filter, if it is not clogged with any debris, then it sounds like your pump motor is bad, maybe need to replace it. lg's are very sensitive........., find out the part number and search it through google. if not email me and i could set sumthin up for you.
drsn777@hotmail.com
dave
Dec 08, 2008 | LG WM2688HWM TROMM SteamWasher
LG front loader te code
A "tE" error code is more than likely the "thermistor" as CoolTech stated but fortunately it is not that difficult to service and doesn't require a technician (warranty expired for me, consider this for your own situation). It supposedly can't be serviced by untrained individuals (thus the directions to call for service) but the thermistor can be found easily by tilting the machine on its back. It is mounted to the back of the drum housing. I removed mine after getting a "tE" error...cleaned and replaced...no problems since! No screws needed to be removed. My thermistor is a small, round, black rubber grommet with the metal sensor pushed through the center. I removed the entire grommet. It easily pops back into place. The face of the grommet and sensor appeared to have buildup from hard water which easily came off without the use of cleaners.
Jul 28, 2008 | LG WM2688HWM TROMM SteamWasher
WASHER NOT WORKING
You have a motor sensor failure and needs to be replaced.  Call a qualified LG technician to remedy your problem.
Nov 16, 2007 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
