Question about Baby Lock Ellure
I put the feed dogs down and now they won't go back up, what do I do now?
    Champion:
  • Baby Lock Expert
  • 300 Answers
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Posted on Sep 07, 2012
  • Baby Lock Master
  • 7,365 Answers
It's very possible that the feed dog lever or knob is damaged & needs to be fixed
Posted on Mar 14, 2012
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Oct 16, 2012 | Necchi 6015 Mechanical Sewing Machine
My fabric dosnt move foward or back wards with the petal or manually ..
if the fabric won't move then there is something wrong with the
feed dogs, check in the needle plate to see if you can see the feed
dogs. you should be able to see them & touch them with your finger
since they are not moving the fabric it would be a good idea to
have the machine checked
I'm putting a link for a free manual for the machine, you can check
in the manual to see if it show where the feed dog lever is on the
machine, if it doesn't show a lever, or the lever is not responding to
movement then the machine needs to be checked to see what's
wrong.
http://www.singerco.com/uploads/download/463_2932_esf.pdf
Sep 04, 2012 | Singer 2932 Mechanical Sewing Machine
I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
Aug 28, 2012 | Brother PC-420
The machine won't stitch anything...
check the feed dogs in the needle plate area to see if there up,
if you can see them & touch them with your finger, I'm putting in a link
for a free manual, so you can see where the lever is to the feed dogs, just
incase they are not up. if they are up then they may need to be checked
to see why they aren't moving the fabric.
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
Jun 27, 2012 | Singer Curvy 8770 Electronic Sewing...
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
O.comI'm having a couple of problems: it seems like the feed dogs need to be adjusted because I need to gently pull the fabric through, from the back, otherwise the fabric won't advance & I...
if you have a manual check where your feed dog knob is, push the knob in the opposite direction,,if that doesn't help then something may be wrong with the feed dogs,,you should be able to see the feed dogs in the needle plate area & to feel them with your fingers.
you may need to have the machine serviced at a sewing shop
Sep 21, 2011 | White Sewing 1730 Mechanical Sewing...
I cleaned my machine, but after putting the plate back on, the feed dogs don't pull the fabric through now.
check the feed dogs to see if their up, you can see & feel them with your finger under the needle plate.
if the feed dogs are not up then somewhere in the cleaning the knob or lever got moved, go back thru what you did to find the feed dog knob,,it's always good to know where it at
Sep 07, 2011 | Brother CS6000i Computerized Sewing...
My Janome Harmony 1017 won't sew all the zigzag stitches. Stitches 5,7 and 8 bog down after just two or three stitches because the fabric isn't moving through the machine. Any suggestions?
when the fabric does not move then the feed dogs under the needle plate need to be checked to see if there up or down.
if the feed dogs are down then the lever or switch needs to be pushed up into the correct position
if the feed dogs are up & they are not moving the fabric like there suppose to, cause it's there job to move the fabric against the presser foot,, then they need to be check
the gears that do the zig zag stitches should be checked to make sure there not worn & weather they might need be be greased
Aug 29, 2011 | Janome Harmony 1017 Sewing Machine
Have Viking 990 and feed dogs not working. Local repair man kept for over a month and then said it was the circuit board and that Viking no longer making circuit board for 990-- or, that machine can't be...
Is it that the feed dogs won't go up and down, or that you can't adjust the stitch length? If the feed dogs won't go up and down after you have released the feed dog button and cycled the handwheel one revolution, than there is a mechanical adjustment needed. I the stitch length can't be ajdusted, that It's either a circuit board of a step motor problem. The repair shop should be able to tell you that they swaped the feed motor with the zig zag motor to test this issue.
Apr 14, 2011 | Husqvarna Viking 1
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
867 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
