Question about Psion NETBOOK PRO 3000 Pocket PC
Netbook pro won't startup
Hello just got a Netbook Pro off of ebay. I put batteries in and charged it and it won't start up when I open it. Nor does it start by pressing escape. Soft reset does nothing. Hard reset brings up the Netbook Pro splash screen and a status bar suggesting Os is being loaded. When the status bar ends the machine just shuts off again and once again cannot be restarted by opening or (esc) Key. Please advise. Thanks in advance!
  • evil_kitty Aug 25, 2008
    my husband bought a psion netbook pro from ebay and it had NO ac adaptor with it, so we bought one from radio shack... now we press the escape "on" button and NOTHING ! omgosh..... what do i do? please help : ((
  • Anonymous Nov 09, 2008
    I tried the fix below (or maybe above -- Ctrl+D+Esc), and it still goes back to a blank screen once it starts the original restart. On the rare occasion that the desktop DOES show, the device quickly freezes up so that no soft reset will work.
Go to netBookPro boot menu as follows: Whilst the splash screen comes up insert a paperclip in the tiny reset hole near the enter key, then press Ctrl + D +Esc(On). Now the netBookPro boot menu should come up, then select the option : !) Clean start main OS (just press Shift +1). Now you should get a reboot with the initial OS-settings. I experienced the same problem after running xclkcfg.exe (an overclock utility for the Sigmarion III ) so best stay away from this utility. have fun Rob.
Posted on Jul 29, 2007
SOURCE:
Licensing key for optimizer pro file version 3.0.1.0
It's a SCAM, delete it. See: http://www.prlog.org/11591763-how-to-remove-pc-optimizer-pro-virus-uninstallremove-pc-optimizer-pro-virus-in-6-minutes.html Use freeware MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, Run a FULL scan, delete ALL results, reboot. Use freeware CCLEANER: http://www.filehippo.com/download_ccleaner/ to clean the junk from your Laptop. This freeware program has many useful tools. In the TOOLS section, select STARTUP, disable ALL unnecessary startup programs/processes to speed up starts and running. The UNINSTALLER is obvious, delete Optimizer Pro.
Apr 17, 2013 | Dell Inspiron Mini 1012 Netbook...
HP netbook won't turn on
Remove main battery and try again, if no! have the power adapter checked for correct voltage, if okay! the DC jack in the laptop is a common source of trouble, at this point it must be dismantled down to the mother board level and checked, I recommend a pro to address the situation.
Apr 13, 2012 | HP Mini 1000 Netbook
Battery is fully charged, but netbook won't turn on unless plugged in.
I would say that you definitely need to purchase a new netbook battery. If it's only turning on when plugged in, then the battery itself doesn't have any more charge cycles.
Oct 10, 2011 | HP Mini 1033CL Netbook
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Hello! I have an acer aspire one netbook D257. I won't open. I was using it for a while then it restarted for updates. While waiting for it to restart, i had the need to go already so i just closed the...
Please try removing battery for a moment (getting cold) and install it again, don't forget to connect charger, after the charge is completed try to turn it on, if there's no motherboard failure the computer should work normally, but if not, maybe you have a "fried" motherboard that needs to be replaced.
Aug 11, 2011 | Acer Aspire One PC Notebook
My netbook is generally running very slow,what can I do to improve speed
Hi
To speedup your netbook follow these steps;
1. Remove if any apps in the 'startup' (like instant messaging, dictionary, world clock openoffice etc (just remove it from the startup folder) Make sure programs like these are not starting up when you boot up else your netbook will feel slow.
2. Be sure that you are running your spyware and virus scanners are working, updated, and have fully scanned your system. These malicious pieces of software can slow down a fast system. They will wreck the speed on your netbook if you aren't careful.
3. One upgrade that you can do to your system that is cheap and easy to do on your own is to add RAM. It's best to maximize your netbook's RAM for best performance.
4. Uninstall unwanted or heavy load softwares.
5. Don't have open programs that you aren't using minimized. If you aren't going to use a program, shut it off. Try to only have a few programs open at once.
6. Use cloud based applications. These are software that you can use that are being processed on a server versus your machine. This is a better way to multitask on your netbook.
7. Consider adding Linux or buying a Linux netbook versus a Windows netbook. Typically the Linux netbooks do run much faster as they are designed to take up less resources making your netbook run much faster.
8. Delete temp files.
9. Running heavy loaded softwares will make the battery hot, that way the battery life is shortened which causes a slow running netbook.
Hope this helps.
Please rate if this solution was helpful, thanks!
Jul 14, 2011 | ASUS Eee PC 900HD Netbook
My battery was was not charged for 2 days over the weekend and now it won't run on batteries. I need to have it on AC power every time I use it.
Laptop batteries can become unchangeable if they are completely discharged, and left that way for too long. This happened to my Asus. IF you leave it charging over night and it still doesn't work you will need a new battery. If you contact the manufacture they will probably charge you over $100 for a new battery. If you use eBay, the average price is $32.
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=IdeaPad+S10e+battery&_sacat=See-All-Categories
Regards, Chris
Jul 12, 2011 | Lenovo IdeaPad S10e Netbook
My netbook will not charge, i am gettn a slow blinking red light but netbook will not turn on
This has several possibilities. Always start with the user manual to see if the blinking light has a listed code.
Possibly your adapter is faulty. There are most likely cheap replacements available on ebay or similar sites. If you have a friend with the same model netbook, you can attempt to charge theres with your adapter. If their's charges, then it is not the adapter.
It could also be a dead battery. Depending on your brand and model, you might be able to find a replacement on ebay. Again, if you can remove the battery and have a friend with the same model, you can test the battery in that netbook. Otherwise, take it to a repair shop.
Finally, and most likely, the ac power jack may have been knocked out of place. That will require a repair person or someone who knows how to solder. You may need to order the part (again, try ebay) and have someone fix it.
Hope that helps.
Apr 05, 2011 | Computers & Internet
Psion Netbook and the rain and Windows
If this is the original Psion NetBook (not the Pro) then you are stuck with the OS you have.
I would remove both the OS/RAM DIMM and the extra RAM DIMM if you have it, as well as removing the CF card. Make sure they are all clean and dry. Take the battery off too. You then need to leave the netbook open, with the CF card slot open in an airing cupboard or other warm dry place for 24 hours. Leave the battery in there too.
Once everything appears dry again, put it all back together and it should work. If not, you'll have to send it off for repair. There are still some ex-Psion engineers in the UK doing netbook repairs, have a look on the pdaforums for addresses.
Hope you get it fixed!
Mar 03, 2009 | Psion NETBOOK PRO
Psion NETBOOK PRO 3000 Pocket PC Logo
443 people viewed this question
Top Psion Computers & Internet Experts
Marvin
Marvin
Lee Michel
Level 1 Expert
ray gallant
ray gallant
Are you a Psion Computer and Internet Expert? Answer questions, earn points and help others
