Question about Kenmore 15864/15862 Top Load Washer
Washer will not cycle
We installed a new timer but it did not solve the cycling problem. The washer will fill and wash until you manually turn the dial to the next cycle. Each cycle must be manually set.
  • black69sting Oct 24, 2008
    I seem to be able to hear the timer running but the dial does not advance.
  • Kenmore Master
  • 19,396 Answers
The cycle does not advance because the mnachine is not able to drain water.
Check the drain hose.
Check all drain lines for obstructions or air gap.
Test the drain valve and/or the solenoid that activates the drain pump and eventually replace it.
Posted on Oct 24, 2008
    Master:
  • 538 Answers
Well..timer is ticking, check?
the knob is not moving, right?
seems that one of two things is happening
the knob is loose(not likely)
or
the mechanism is trashed between the clicker and the ticker feel up to doing the swap out of that whole mechanism?
  • A Womans Computer Man
    A Womans Computer Man Oct 24, 2008
    then replace that whole mechanism..that part of your technical skill set?
  • 13,433 Answers
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Ekse Oct 24, 2008
    The dial might be the problem?
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
Sep 18, 2016 | Kenmore Washing Machines
Kenmore will not agitate
The timer is the most common problem. Call any appliance parts store and tell them the model number and ask for price for new timer. Also call sears appliance parts and get price. But a new timer and install it.
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer is not filling up with water when we turn on.
YOU PROBABLY NEED A NEW TIMER. YOU SHOULD BE ABLE TO REPLACE YOURSELF AND ORDER ON LINE. GOOD LUCK
Jan 02, 2009 | Washing Machines
New timer on my washer still won't cycle properly.
SOUNDS LIKE THE MOTOR THAT ADVANCES THE TIMER IS NOT WORKING OR NOT GETTING VOTAGE TO IT. CHECK VOTAGE TO TIMER MOTOR
Jun 01, 2008 | Frigidaire Washing Machines
Kenmore 15864/15862 Top Load Washer Logo
644 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
