Question about Toshiba Satellite A25-S207 Notebook
SONY VAIO ASSEMBLY SHEET FOR PCG8M2R LAPTOP
AM LOOKING FOR EXPLODED VIEW OF PCG8M2R
    Brigadier General:
  • 6,966 Answers
For some Sony Vaio, pls try here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 24, 2008
Free download schematic diagram laptop mother board toshiba tecra8000
Believe problem to be one of the Power MOSFET's, in the DC - DC circuit on the motherboard
http://en.wikipedia.org/wiki/DC-to-DC_converter
Using the HP Pavilion dv6000 series and Pavilion dv9000 series, of Notebook PC's for an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
The two Power MOSFET's used; are the Fairchild Semiconductor Industries -FDS6679 - Power MOSFET, and the Alpha & Omega Semiconductor LTD - AO4407 - Power MOSFET.
Showing availability and cost. Using just FDS6679 for an example,
http://www.mouser.com/Search/Refine.aspx?Keyword=fds6679
Obsolete. Using cross reference match example,
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FDS6679AZ/?qs=sGAEpiMZZMshyDBzk1%2fWi1qxDdW%2fXBi2qgMuZEfLVO4%3d
One dollar and one penny USD.
AO4407 is obsolete too. Cross reference match example for it, cost is 78 cents USD.
NOT stating the P.MOSFET's are used on your Sony VAIO's motherboard. Showing what a Power MOSFET looks like for this type of application, and availability/cost.
Look on your motherboard in the DC - DC converter circuit area, where the DC Power Harness plugs in.
[The AC adapter (Charger), plugs into the DC Power Jack on the laptop. (DC_IN)
For your laptop the DC Power Jack is connected to wires, that end in a male plug connector. The male plug connector plugs into the motherboard.
It is now called a DC Power Harness ]
Let's take a brief look at a motherboard example,
http://www.ebay.co.uk/itm/Sony-Vaio-PCG-6L1M-Laptop-Motherboard-A1171213A-Spares-Repair-NO-POST-/360566230317?pt=UK_Computing_Housings_Touchpads&hash=item53f36c0d2d
(Sony VAIO PCG-6L1M and VAIO VGN-B1VP are supposed to be the same)
The Main view shows up automatically, with the Top view of the motherboard.
Scroll down for Bottom and Top view.
Again there is a Main view, and this time two smaller views to the Right.
Top small view is Top view of motherboard.
Bottom small view is Bottom view of motherboard.
Looking at Bottom view of motherboard, believe DC Power Harness plugs into the Right side.
Series of Power MOSFET's are on the right side, also.
WEAR an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Here is free access to the Service Manual.
You want VGN-B
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-sony
Bottom line -> VGN-A
Scroll across, click on VGN-B
(It's a PDF file)
http://www.youtube.com/watch?v=3NN7UGWYmBY
Regards,
joecoolvette
May 01, 2013 | Computers & Internet
Looking for timing belt diagram of a 1996 MX6 v6. Where can I get one online?
I just find this diagrams (click over images for zoom)...
Fig. 4: Exploded view of the timing belt cover for the 2.0L engine
Fig. 10: Exploded view of the 1.8L (K8) and 2.5L engines timing belt cover assembly-2.3L engine is similar
Hope this helps (remember to rating this free answer and leave some testimonial comments).
Oct 08, 2011 | 1996 Mazda MX-6
How much the price of vaio sonny lop top thanks a lot.
I'm glad to provide the price of the VAIO Notebook. Please click hear to view the price of the Notebook.
However, I have seen the same model with white color with a little low price. The only difference between E/P and E/W is it's color and P refers to Pink and W Refers to White.
Click hear to view the price of the E/W from Sony itself.
Thanks for understanding. Please let me know if you require any clarifications.
Jun 25, 2011 | Sony VAIO VGN-CR220E/P Notebook
I want downdload all driver for sony vaio laptop vgnbx165pc
You can download the device drivers from the Sony WEB site.
Select your model notebook and the Windows XP or Vista drivers you require. Please click on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
Feb 24, 2011 | Sony Vaio VGNBX165CP Laptop Charger...
I need to know how to install a laptop hinge on a sony vaio a690? Is it required that I remove the lcd when I attempt to install the hinge?
As the hinge is what binds the display assembly to the laptop itself, you will need to remove the display assembly in order to replace the hinge. However, if you are only replacing the hinge cover, then you don't have to remove the display assembly.
Jan 09, 2011 | Sony VAIO VGN-A690 Notebook
How do i stop the keyboard from being stuck? I have to hit each key about 3 times before it will compute. I have a sony vaio vgn-cs11oe
Please take your laptop to the service center and get the rubber sheet cleaned(which will be present between keys and the Integrated chip). may be a dusty layer of rubber sheet should have made it harder to react.
also try cleaning the underside of keys using a vacuum cleaner before taking it to the service center.Please try to open the laptop for yourself as it may lead to violation of warranty aspects.
thanks.
Jan 07, 2010 | Sony VAIO VGP-WKB1 Keyboard
Swingarm bearing and seal assembly
If you just are looking for an exploded view. You can view, look only at bikebandits.com. Can't print or save, just look. Hope this helps.
JP
Oct 27, 2009 | 2005 Harley Davidson FLHTC - FLHTCI...
Replace DVD Drive in a Sony Vaio PCG-K23
Here is the service manual for your unit with an exploded view of the notebook. Post back here if the guide still help you solve your problem.
Feb 25, 2009 | Sony VAIO PCG-K23 Notebook
I took the transmission out and it won't go allthe way back in.
For an exploded view of the inside of the WASHER, go to either searspartsdirect.com or appliancepartspros.com. Just type in your COMPLETE model number and both sites will have what you're looking for. I do not know any where that would have an exploded view of the inside of the transmission, as these units are not normally repaired by the consumer. They are replaced as a whole assembly. If you have questions, please let me know. I hope this helps you.
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
I need a service manual/exploded view
If ur laptop is in under warranty then u take from nearest service center.
Oct 06, 2007 | Sony VAIO GRZ660 Notebook
Toshiba Satellite A25-S207 Notebook Logo
1,040 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
