Question about Poulan Garden
I have a poulan 2150 that will not crank. when i pour gas in the carb it cranks up then cuts off. i've cleaned everything i know to clean. what next?
2150
  • 211 Answers
SOURCE: Trouble with Poulan 2150 Chain saw automatic chain oiler
Hi
It is gear driven oiler and there is not any adjusment for it.
regards savumihai71
Posted on Dec 15, 2008
  • 149 Answers
SOURCE: poulan 2150 w/ walbro wt324 carb fuel line reassembly
the fule line that comes from the filter/ pick up will go straight to the nipple usualy the one closest to the middle of the carby.
the other hose comes from the carby to the in or **** side( punp it you can feel it)of the primer and then goes to the tank that is the return/ prime, nothing is conected to it in the tank. if you have the carby one the wrong way around it will not prime. just swap them over..
Posted on Jan 12, 2009
Editor925
  • 285 Answers
SOURCE: I have a poulan 2150 chainsaw and the chain never
Firstly consult your manual regarding carburettor settings. There should be a high and low speed adjustment on the saw, often called or labeled as "L" and "H".
These are often located on the main motor body, closer to the handle on one side and require a screwdriver or similar to adjust. They might be buried and you have to look down the adjustment holes in the outer body to see the screws.
Basically you need to adjust the "L" or low idle screw.
Firstly, warm up the chainsaw and allow it to get up to temperature... The blade, as you say will probably be spinning still with hands off the throttle... Grab your screwdriver and adjust the "L" or low idle screw turning it counter-clockwise (at least on most saws) very slowly until the chain just stops turning on the bar. If you go to far you may stall the motor. You just want the chain to have just stopped moving on the bar, and that is your "L" setting position...
Has to be done with a warm engine though.
Please rate this solution on FixYa!
Thanks.
Posted on Apr 01, 2009
dontbother10
  • 2220 Answers
SOURCE: how do you re assembly brake handle poulan 2150
Hello Larsens;
A Poulan "2150 Predator Gas Type 6" IPL follows (may not be your saw)(the LE suffix is a Wood Shark) http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
There is no breakdown, they want you to order a new cover $20±. The cover appears on different print names with different models (Handle & External Assembly) above.
Poulan.com (all)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Do you have a friend with a cover you can look at? The brake will need to be lached open (enlarged) to refit the clutch cover on your saw.
Detail A here is a good representation of a Husky chain brake, they are all similar and this may be helpful.
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601077.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
SOURCE: I need the routing of the gas lines on a poulan
how to route the gas tank lines in a poulan chain saw
Posted on Nov 18, 2010
Gas pouring out of overflow tube, gas in crank case
Definitely a carb. clean problem. Gas is more than 6 months old & has float needle stuck. Clean carbs. & always replace the float needle valve assy\'s & bowl gaskets. There is nothing you can put in the gas tank to clean carb correctly.
Jan 20, 2014 | Yamaha Motorcycles
I HAVE POULAN 2150 CHAINSAW IT WILL CRANK WITH CHOKE PULLED OUT IN ON POSITION BUT SOON AS I PUSH CHOKE IN TO OFF POSITION SAW CUTS OFF . I REPLACED FUEL LINES AND TANK FILTER AND PRIMER BULB
Try testing it with a known good carb. The float and needle may be worn out. Since it starts, it is obviously a fuel problem and not an electronic one. Or if you have the means, buy a new carb.
Nov 23, 2013 | Garden
Chainsaw will not crank
this is classic fuel starvation, start, if you have not already done by replacing the fuel filter in the tank, if no better replace the fuel hose in the tank up to the carb, if no better remove the carb, under the pump side carb cover ( normally alluminium ) here you will find the an internal filter, clean or replace, if the pump diaphram curls up then replace, remove the metering side cover of the carb, check the metring lever here moves freely and lifts the needle, when re assembling on the metering side the gasket is used as a spacer so must go on first then the diaphram and cover, on the pump side the diaphram must go against the carb body followed by the gasket and cover, re set the jet screws to one and a quarter turns out from closed, if the saw is still not starting it is most likley a massive air leak, check the manifold between the cylinder and the carb for cracks, splits or loose, replace the crank seals, replace the cylinder base gasket
Feb 11, 2012 | Poulan Garden
I have a 25 cc Craftsman weedeater. Using fresh 40:1 gas. I've replaced the fuel lines, cleaned in tank filter, cleaned and rebuilt carb and getting spark, but it still won't start. Also cleaned...
the other possibilities you have is a bad crank seal, or a flywheel came loose and its out of time, will it fire on carb cleaner sprayed in the carb, If it runs for seconds and , then I would say it's not getting fuel, If it only farts once or twice then I would check crank seals cause if they are leaking then your crankcase cannot draw vacumn which in turn causes fuel pump in carb to draw fuel, If you have to check flywheel pull it apart and take flywheel nut off and pull flywheel off and inspect the key that is built into flywheel to see if it is sheared off or messed up, also while checking muffler check for the opening that the mud dobbers havent put mud in muffler pipe, good luck
May 15, 2011 | Craftsman 25cc Gas Line Trimmer
Engine stalled out,would not start, pour gas in carb,cranks,keeps running,until idle falls below 12to1500rpm,than stalls out again and will not crank,repeat gas or starting fluid in carb,cranks runs and...
This truck is fuel injected, the problem sounds like a weak fuelpump, it runs when you pour gas into it until that gas runs out, the first thing is to test the fuel preasure, if the pump is weak it may run with gas poured into it but wont idle, also a common problem is the coolant temp sensor and the ground wires to thermostat housing bolt but i wont bet its the pump inside the fuel tank, if you put a fuel gauge on it there should be at least 55-61 psi if its a few pounds lower it can cause problems, you have everything else and it runs with gas poured so its a fuel problem check the preasure, theres a valve up top on the fuel line to connect a fuel gauge to it, start there hope this is helpful.
Dec 27, 2010 | 1993 Chevrolet C1500
1989 jeep cherokee 4.0 cuts without warning or when you let off gas pedal
check the crank position sensor and the throttle position sensor
Oct 15, 2009 | 1989 Jeep Cherokee
17hp b/s intek OHV after 30 min mowing starts running rough
if gas is in the oil the needle and seat in the carb are bad or some thing in it. the gas will go in to the crank case and load the cylinder with gas. you can take the carb apart to see if something is in the seat. or replace the carb
Jul 26, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Briggs and statton carb pouring fuel out
Could you have possibly lost a plug in the carb ?
Jun 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Gas pouring out of air filter
carb is gummed up from the old fuel turning to varnish and clogging the jets. while trying to start, its trying to inject fuel, but its clogged and taking the path of least resistance (coming out the air filter).
you'll need to drain the gas tank and remove the carb to clean it out. if unfamiliar or uncomfortable doing this, then take it to someone to do a carb cleaning.
Jan 29, 2009 | Garden
Garden Logo
52 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
