Question about Honeywell Heating & Cooling
This is a question about my "Magic Stat" thermostat. When I came home today, it was flashing 6AE Low. What does this mean? Sorry, I have no manual.
2 Suggested Answers
  • 77 Answers
SOURCE: I have a honeywell thermostat
Remove main stat from subbase. On back of main stat there are some screws used for different settings. Screw "C" if for fahrenheit and celcius. Screw in for fahrenheit and out 1 turn for celcius.
Posted on Jan 17, 2011
Can I replace my old Magic Stat CT3100 thermostat with a Honeywell CT3200 thermostat?
yes just make sure u relace all the wires in proper order, r-rc, w , y g,, remove one wire from old stat and install on new one or make drawing and write down all wireing colours and letters
Dec 21, 2015 | Honeywell Heating & Cooling
Dca213d window unit keeps freezing is it thermostat?
Check for badly bent fins or obstructed/dirt impacted fins on the outside of the unit. Could also be low on gas. Try setting the t/stat to various settings see if its turning off/on at higher settings, if it does most likelt stat is OK. Also make sure you drian is clear.
Aug 12, 2014 | Carrier Heating & Cooling
Home Thermostat reads low batt
I have ran into this problem before. I have actually had low batteries I thought were good too ha! I have had to actually reset the stat to get the low battery to stop flashing. There are multiple ways to reset the thermostats, depending on model, but removing the batteries and waiting has worked, along with actually having a reset button somewhere on the stat. Hope this helps!
Nov 30, 2013 | Honeywell Programmable Thermostat Heater
My carrier AC(model: Optima D plus) is displaying a error "E3". Can someone suggest a solution to it.
An E3 error on your thermostat (T-Stat) has the following description from your manual:
"Brownout condition or too low of voltage to thermostat. Double check wiring and check for
24 vac between R and C. E2 will clear 15 sec after proper voltage is restored."
If you are unsure how to check the low voltage to your t-stat, then please call a professional in your area to check the t-stat wiring and the transformer in your furnace.
Jun 13, 2011 | Heating & Cooling
I want to stop my philips magic 5 "replace inkflim from flashing. I'm not able to access my messages or send faxes. I dont have a replacement inkfilm. Thanks
the fax hackers are still researching the method to disable plug-n-print chipcard in magic 5 series. magic 3 series has been solved in hidden service menu.
This means you need to buy a new inkfilm with new chipcard included. sorry.
Apr 04, 2011 | Philips PPF-531 Plain Paper Thermal...
Check engin light comes on and vehical shutters when trying to excellerate. checked water and it was out, put fresh atifreeze 50/50 mix and it is still doing same thing. this vehical has a new water pump...
If you replace the water pump and thermostat and nothing is leaking, and still the coolant is low, then you vehicle is burning coolant, that give you a misfire and a flashing check engine light. so look like you need a head gasket job.
Sorry if I don't put things in a nice way.
If the thermostat is bad either the temperature is low, or is hot but no misfire (chatters)
Jan 16, 2011 | 1998 Toyota Camry
6AE Lo
6AE Lo is probably 'bAt Lo'. Batteries are low and need to be replaced.  It looks like 6AE Lo because of the digital readout (b looks like 6).
http://www.espenergy.com/faq_honeywell_thermostat.htm
Model number shouldn't change what the readout means.
Oct 14, 2009 | Honeywell CT3600 7 Day Electronic...
I want to wire digital wall mount thermostat to my window AC unit
I think you are wright and also may lead to short cycle and burn the start relay on compressor(it may be too hot to be without air just now)try bigger relay when it is a bit cooler and 24,000btu must220-240 volts be very careful
Aug 20, 2009 | Heating & Cooling
Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
Flashing battery symbol
I had this same problem today.  I called Honeywell and they said the flashing broken battery symbol may mean low batteries, or it may mean the battery type is incorrect.  They recommend only non-rechargeable alkaline batteries.  I was using rechargeable NiMH batteries.  Even though they were fully charged, I had the flashing battery symbol and the thermostat relay would not work.  I replaced with alkaline, the flashing battery indicator went out, the thermostat works again.
Odd that it worked for 3 months on the rechargeables after first install. I did notice the broken battery symbol came on after the first few days, but I checked the battery charges and they were good, so I disregarded the symbol until the thermostat stopped working today.  Apparently there is something about the NiMH performance characteristic that the thermostat doesn't like.
Jan 31, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
19 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
