Question about Ovens
Bosch HBL64 Series Wall Oven Fan Intermittent
The fan on my electric wall-mounted oven is intermittent. It cycles on/off during the cool-down phase, but today the fan didn't kick-in when I turned it on bake mode, but it worked fine on convection mode. Later, I turned it back to bake mode and it worked fine. Also a question regarding the convection mode: there is a loud buzzing noise (not the fan!) that goes away once the set temperature is reached. Any feedback is appreciated.
4 Suggested Answers
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    eagle338
    • 4889 Answers
    SOURCE: F2 fault, continuous fan after clean cycle for Jenn-Air electric convection wall oven
    The "F2" means the oven control senses runaway temperature. The cause of the problem could be the oven sensor, the oven sensor wire harness or the power relay board.
    PS:please disconnect your oven from power supply completely before continuing.
    Open the control panel and measure the oven sensor resistance at the control board. It suppose to be about 1100 Ohms at the room temperature.
    If the reading is wrong do the same test at the oven sensor connection (where the sensor wires goes through the back panel).
    If the reading is still wrong - replace the oven sensor.
    If the reading is correct, check the wire harness and the connector itself (it's better to eliminate the plastic plug and hardwire the oven sensor).
    If there is nothing wrong then the power relay board has to be replaced.
    Posted on Nov 07, 2008
    What are the dimensions of a chef baroness integra gas wall oven
    You need the Chef Model number, then click on the model and then on 'More'.
    chef integra baroness wall oven 92 60 chef Compare Cheap chef integra...
    Chef EXC627W Wall Oven
    Compare prices $849.00 Chef EXC627W 60cm electric fan forced wall oven with separate grill and 60 minute timer in white Separate grill 60 minute timer Easy clean formed shelf supports Cooler door temperatures with air cooled door Wall installation Cooling fan Oven size (cm): 60 Oven - internal dimensions (h x w x d) (mm): 376 x 475 x 432 Separate grill - internal dimensions (h x w x d) (mm): 216 x 475 x 432
    Specifications Style of Oven
    Separate grill/wall
    Oven Type Electric
    Width 888 mm
    Depth 595 mm
    Height 573 mm
    Or contact them direct
    Welcome to Chef
    https://www.chefappliances.com.au/Explore Chef's range of products! ... The simple touches that make Chef functional and easy. Fingerprint. Anti-fingerprint. A special stainless steel finish means our ovens stay free of messy prints. Cooktop options. Gas, electric solid or ceramic. image 1. Boils faster than gas? Easy. The Induction cooktop provides modern, ...
    Apr 08, 2018 | Ovens
    The fan copntinues to run after oven is turned off
    Most electric ovens have 2 fans. One is a fan forced fan at the back of the oven cavity that you can generally see spinning when the oven/fan forced option is selected. The other is a cavity fan which is situated between the outer skin of the oven and the oven itself. There are generally located at the top of the oven. Because the oven is a wall oven that sits in a tight cavity it cannot cool down easily. The job of the cavity fan is to cool this cavity down by blowing the hot air in the cavity out a small hole, normally in the front of the oven. When you turn the oven off this fan might operate for 5 to 10 minutes until the oven cavity cools sufficiently. If there was no cavity fan the oven and/or cupboard would overheat.
    Feb 06, 2011 | Viking Designer DESO127SS Stainless Steel...
    While baking oven starts broiling with no input from controller. f2 is displayed on screen
    Hello there:
    F2
    Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
    · Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
    · Control senses oven temperature above 935 degrees F with the door in the locked mode.
    · Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
    · Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
    · Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
    · Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
    Sep 27, 2010 | GE JKP15 Electric Single Oven
    Error message on JJW9530DDS Jenn-air wall oven is 4d21
    no/low cooling fan rotation (No RPM) single cavity or upper oven - check connection at cooling fan if ok, replace blower - DO NOT REPLACE CONTROL
    Mar 06, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
    Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
    There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
    Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
    Ge oven turns off by itself, and sometimes gives
    F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
    Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
    Oven Stays Cold - Intermittent Problem
    hi thanks for the question look at the cord that plugs into the wall you could have a bad connection in that outlet remove the plug from the wall and look at the prongs if its a bad connection they will be discolored check that the appliance doc
    Sep 25, 2008 | Thermador C301U Electric Single Oven
    Bosch HBN 642 -- single oven cycles and doesn't get above 325
    WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
    If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
    May 28, 2008 | Ovens
    Bosch HBN 455 Oven Cooling-Fan Issue
    After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
    Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
    Ovens Logo
    41 people viewed this question
    Top Ovens Experts
    ashburton
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
