Question about Kowa Optics
Spotting scope repair
Loose interior focus lens
4 Suggested Answers
cammedic
  • 667 Answers
SOURCE: Bausch & Lomb 60mm Spotting scope focus screw
Try here: Eagle Optics
2120 W. Greenview Dr.
Middleton, WI 53562
Posted on Jan 25, 2008
Buschchris1
  • 474 Answers
SOURCE: SPOTTING SCOPE WITH LOSE INNER LENS
You will need top take it to someone you specializes in telescopes and can get you the right part and install it correctly, Telescopes are not everyday items you can get parts for anywear. Try a scientific store and ask around, they may know somewhere to take it.
Posted on Feb 23, 2008
  • 115 Answers
SOURCE: Loose internal lens
I would call bushnell at 800-423-3537 option 2 they are the ones that produced this.
Posted on Oct 06, 2009
What is the ideal spotting scope Lens Size?
You simply need to choose if you prefer a better image quality or a smaller and lighter spotting scope. A spotting scope with a larger lens (60mm to 100mm) will have better light-gathering capability than a smaller 50mm lens spotting scope. This means that the image you see will be brighter and clearer. You will also enjoy a wider field of view. On the other hand the bigger the lens is, the larger and heavier your spotting scope will be. Larger spotting scopes are also more expensive.
Think about where you will be using the spotting scope the most. If you normally stay at a fixed location for a long period or don't need to worry about extra weight then opt for an 80mm to 100mm scope (if you can afford it of course). If you like to travel light or move around more than a 50mm to 60mm scope will suit you better. Some 50mm scopes can even be used without a tripod when needed.
May 27, 2018 | The Optics
How to Spotting Scopes Work?
Spotting Scope is a type of telescope typically used for observing wild animals and birds. A spotting scope features more magnification than a conventional binocular but less than an astronomical telescope.
The utility of a spotting scope becomes most obvious when the identification of an animal going in a large herd is required. Figuring out a specific animal from other look-alike animals becomes easy with such a device. For digiscoping purposes, few things can beat the power of spotting scopes. It is possible by using binoculars or telescopes to take a closer look at birds or other animals, but if you want a precise view of your target animal, a spotting scope is preferable.
Spotting Scope Features Explained
  • Objective lens
    Objective lens, also known as the Front lens, determines the image quality at higher magnifications. The diameter of this lens ranges from 50-100mm in size. It is also called "Aperture" of the lens. It is wise to buy the highest size of the objective lens considering its weight. Larger lenses allow to pass more light and create more bright images. This means you will get higher image quality with the larger lenses.
  • Lens Coating
    Manufactures often apply the chemical coating, which is known as Lens Coating, on the lens to reduce noise and increase light transmission. They also offer "fully coated," "multi-coated" and "fully multi-coated" lens to improve image quality. The premium quality spotting scopes' lenses are multi-coated with multiple layers on the surface.
  • Focusing
    There are two types of focusing mechanism in the spotting scopes such as Helical and Knob focusers. The focusing characteristics determine how quickly you can focus on the object with maximum precision. Between these two options, the helical focuser is the finest option for birding as it can change magnification rapidly along with the movement of the bird. For hunting or spotting slower animals, Knob focuser is best as it gives you more precise information than the former one.
  • Eye relief
    The eyepiece remains at a little distance from the users' eyes. This distance is called the eye relief where the light rays transmitted from the object pass to enter into your pupil. The comfortable eye relief distance is about 15mm to see the full field view. This feature is very important for those who wear eyeglasses. Nowadays, manufacturers are offering long eye relief for those who need to wear eyeglasses for convenient viewing.
  • Image Quality
    You might have seen some designation on the glass label of the spotting scope such ED glass, APO glass, HD glass, Fluorite glass. These special qualities of glass will cost you more but create a huge difference in image quality comparing low-quality lenses. Remember, you must pay for the good quality images when it comes to buying any types of optical instruments.
  • Magnification
    The magnification of spotting scope is higher than standard binoculars and varies between 15x to 75x. The power of the eyepiece determines the magnification of the scope. The important fact you should know that image quality drops off as the magnification goes up. Even premium quality scopes also lose a little quality at the highest magnification.
The condition of the atmosphere has effects on birding, hunting and digiscoping too. Humidity, ever-moving air, dry climates, dust and so on hinders the magnification and image quality at large.
Apr 08, 2018 | Optics
How to use a spotting scope for shooting?
A Spotting Scope is an essential element for hunters and shooters. This small device is technically a special type of telescope used for hunting, magnifying and watching an image or object more clearly. The methods use a shooting spotting scope does not involve much difficulty.
Here is the method:
Comfortable position
For a perfect shooting experience, you need a comfortable position. If your comfortable position is unable to help you fix the targeted area, you are likely to miss the hit or glance.
Attachment of the spotting scope with the tripod
Having an accurate view of the targeted area is important. Due to this reason, shooters need to position the spotting scope with a tripod so that they can see the targeted area very clearly and accurately.
Adjustment of the magnification level
The lens and magnification level should be adjusted so that you can get the appropriate view of the targeted area.
View of the targeted area
After fixing the targeted area, you have to adjust the magnification level with the lens to view the targeted area. At the time of using scopes, you will find some problems that magnification will present. If you fix the magnification and focus firstly, you may not find the target. You have to first view the target, and you have to adjust magnification level as required. Here, you should bear in mind you will have to go with the slow magnification process because the fast magnification process cannot give the accurate target.
Adjustment of the focus
You have to know how to reset the focus because you will need to do it again and again. It may sometimes harm your eyes with the magnification level being set to high.
Focusing on target is important for shooting and the spotting scope is also important for this purpose. For acquiring a specific target, it is important to use magnification level with the spotting scope.
You should follow all the methods of using explained above. There is no alternative way to learning how to use a spotting scope for shooting except these methods.
Apr 05, 2018 | Optics
Which is the good spotting scope for higher amount of light?
Bushnell Trophy Xtreme Spotting Scope
Overview
Bushnell Spotting Scope has extra power for extra range; its BaK-4 Porro-prism design delivers magnificent clarity in a traditional design. The multicoated optics ensure maximum light transmission for the brightest and take the images more colorful and clear. If you are searching Bushnell Scope that can be used for different activities, you should consider Bushnell Trophy Xtreme Spotting Scope Review.
The highly refractive BAK4 Porro prisms diminish spherical deviations for increased edge-to-edge sharpness and help progress depth of view. This combination of optics and coatings creates a spotting scope that produces clear, bright, highly contrasted images with the exact color transmission.
The rubber-armor structure stands up to demanding use. This scope is 100% waterproof and fog proof for wet hunting conditions. It also Comprises compact tripod with window mount, compact soft case, and waterproof hard case.
Specifications
  • Brand:Bushnell
  • Viewing Configuration:Straight
  • Magnification:16-48X
  • Power Variability:Variable
  • Objective Diameter:50 mm
  • Close Focus Distance:25 feet
  • Length:13 inches
  • Weight:31.4 ounces
  • Field of View:125-60 feet/1000 yards
  • Eye Relief/Exit Pupil:16 mm/ 3.1-1 mm
  • Optics Coatings:Fully Multi-Coated
  • Glass:BaK-4
  • Focus System:Focus Knob/Single Focus
Feature Analysis
  • Porro Prism Lens
    Though many optics producers keep on trying to transform roof prism lens, Porro prism lenses are more affordable and light-efficient. These Porro prism lenses can display images with better contrast than roof prism variations. This is how Bushnell Spotting Scope is more reliable and affordable for its high-quality performance.
  • 20-60×65 Zoom Magnification
    The wide range of magnification allows user flexibility for long-range view finding. You can observe details with 65x zoom for long range objects. But, you can still enjoy an increased field of view with 20x zoom. This is used when separating the areas for closer zoom viewing later on.
  • 65x Lens Light-Gathering Capability
    This advanced magnification lenses can light gather at long distances. The Bushnell Trophy 20-60x 65mm Waterproof Spotting Scope resolves this issue by designing 65x zoom lens in a way that brings 17% more light than most high-zoom lenses.
    If you fully read Bushnell Trophy Xtreme Spotting Scope Review, it will support you how to setting zoom for longer distances images.
  • Waterproof Construction
    When you go out in nature, this waterproof construction anticipates you about rain or even snow. It is pretty obvious that any liquid that leaks into your scope will detract from the overall image. But many people do not consider the effects of concentration on the inside of the lens.
    This spotting scope is actually water and fog proof not only for outside moisture but also prevents lens fogging from risky temperatures.
  • Fully Multi-Coated Optics
    The multi-coated lenses prevent any reflections in the glass that can delay your view. The sunlight at certain angles can cause reflections from water or wet surfaces that prevent the clear view of the images. That is why; Bushnell uses multi-coated lenses to remove any kind of reflection.
  • Well-designed Equipment
    The tripod often needs to hide from animals, and the scope cases also need to protect their insides from both jostling and the outside elements. The Bushnell Trophy XLT comes with both a hard-side case and a soft side case. The hard side case protects you from outside damage and a soft-side case protect you from a bumpy road when you are riding.
Mar 18, 2018 | The Optics
What are the features of Spotting scope?
Landove Prism Spotting Scope Review Best Spotting Scope In 2018
An overview of Landove Prism Spotting Scope
Everybody cherishes a lovely vacation. Recreational activities like hunting, hiking, wildlife or bird watching refresh our soul. In this case, enjoying a beautiful scenery spotting scope becomes a necessity to have a wonderful sight and captivate such sight in our mobile screens and cameras.
Most of the spotting scope provides this sort of view, but Landove Prism Spotting Scope is unique. We face trouble when we have to carry too many devices and skip perfect glimpse managing those devices. But Landove Prism Spotting Scope is different because it has a space to adjust our mobile phones or camera of such size.
The Landove Spotting Scope review holds the scope's other benefits which are described below.
Specifications
  • 20×60x zoom eyepiece
  • Prism: Bak4
  • Objective lens diameter: 80mm
  • Eyepiece diameter: 20mm
  • F.O.V angle: 1.58 degree-0.91 degree
  • F.O.V (feet /1000yds): 82.9ft-48ft
  • F.O.V (m/1000m): 27.6m-16m
Feature Analysis
Superior magnificationLandove Prism Spotting Scope review states one of its best features which is a 20x60c zoom. With a higher magnification like this, you can click or picture video clips of scenes located very far. But that would not ruin the quality rather it will be clicked with much clarity.
WaterproofWeather can be a great hassle sometimes and mess up our entire plan. But this spotting scope will not let that happen. Landove prism spotting scope is waterproof and allows apprehending the beauty of nature during rain too.
Dynamic lensThe spotting scope has superb focusing system because of its dynamic lens. The lens allows you to have a clear aim and focus on the target.
Fully multicoated opticsThis Landove Prism Spotting Scope review has already stated about the clarity given by the spotting scope. It has a fully multicoated 65mm green film objective lens, superior quality prism, and eyepiece. These specialties let you have a brighter and fresh picture.
Cell phone adapterLandove spotting scope digi-scoping adapter which can adjust your phone to the scope. This adapter helps you to take picture or video clips of the heavenly nature and charming animals without any trouble. For this reason, people all around the world prefer this spotting scope so much.
Standard coating and materialsThe spotting scope is a very light material, but this one is strong enough to be used often. It has a fine design with durability, metal framework and contains rubber armor. The tripod can be attached to the spotting scope which is portable and durable too.
Pros & Cons
Pros
  • Cell Phone Adapter
  • High-quality lens
  • Portable
  • Affordable
  • Easy to use
Cons
  • The Camera lens arrangement sometimes causes barrier for the scope eyepiece.
Final Verdict
Nature always amazes us. Travelling and sightseeing are also required in order to explore the beauty of nature. Spotting scope has become an additional requirement with this. Landove Prism Spotting scope review has remarked all the specialties and a disadvantage of this scope. But this disadvantage can be easily ignored in exchange for such crystal-clear vision.
Landove Prism Spotting Scope has become a top choice for people worldwide because it lessens the difficulties of carrying more than one device. Its features will always increase your excitement and add liveliness to your trip, bird watching or archery.
We can conclude our review by saying this scope is worth purchasing and a great deal undoubtedly. Hopefully, this landove Prism Spotting Scope Review will guide you through the buying process.
Mar 12, 2018 | The Optics
Which is the best hunting spotting scopes?
Vortex Razor HD Spotting Scope
This is a spectacular spotting scope which is a masterpiece of the well-known, vortex optics.
The Vortex Razor HD Spotting scope is filled with the premium high density and extra-low dispersion glass which will definitely give you the ultimate resolution for every image by providing rich color and contract.
Moreover, the ultra-hard-coated Armor Tek will efficiently protect the exterior of the lenses from any particular scratches, prevents staining from oil and dirt too.
As for the linear field of view, you can get 117 -60 feet per 1000 yards. The angular field of view for this spotting scope is 2.2-1.1 degrees. As for the close focus, it can come to an amazing 16.4 feet. This spotting scope would be perfect for getting really close and personal during your hunting surveillance.
The eye relief for the Vortex Razor HD spotting scope ranges from 18 mm to 20 mm. For this eye relief, it will be very comfortable to scope even with glasses on. The exit pupil can be adjusted from 1.42mm to 4.25mm. Being able to focus with this spotting scope is extremely easy too. Amazing detail too if you want to sight further, even into outer space!
To touch on the physical aspect of this spotting scope, it is generally large in size. The spotting scope has an 85 mm objective lens and an eyepiece which has a magnification that can be adjusted from 20x to 60x. The objective lens will provide you with image of great clarity which is made by Vortex.
Not only that, this spotting scope has Dual Focus Knob which is necessary for ultra-precise focusing while making it much easier for you to manipulate the focus of this scope. There is a course knob and a fine knob to provide for maximum manipulation during focus. The length of this spotting scope is 15.3 inches while of this scope is 65.7 ounces. Although it does feel a little heavy, this scope is extremely sturdy!
To extend more about the objective lens, it can significantly reduce the amount of glare while being immune to raindrops and even snow since the Vortex Razor HD spotting scope is waterproof, rugged and even fog proof.
Also, there is a helpful finder on the side of the spotting scope. The balance is extremely good too even on or off the tripod.
Furthermore, the Vortex Razor HD Spotting Scope has a Dielectric prism coating which will provide the clearest and brightest images you will ever see with a spotting scope. It is also known for the great color accuracy for every single images. All and all, beautiful to look through and extremely pleasant to look at.
The Vortex Razor HD Spotting scope also comes with a proprietary XR anti-reflective coating which will significantly augment the light transmission for maximum brightness while you are spotting with this premium scope. Basically, the XR lens coatings will increase light transmission by providing multiple coatings on every single air-to-glass surfaces which are present in the spotting scope.
As for the design, the Vortex Razor HD spotting scope has an angled body design which is greatly sought for because it will allow a lower mounting height making it much more stable in the wind while giving more comfort when you are looking through the spotting scope with glasses for a long period of time.
In addition, the spotting scope comes with a triplet apochromatic lens which greatly reduces chromatic aberration. Also, the Vortex Razor HD has a built-in sunshade which can be equipped on a sunny day. The XT optical design also helps in the reduction of aberration while aiding in making distortion-free images which is needed for accurate image.
The Vortex Razor HD spotting scope uses Porro Prism which is popularly known to offer maximum image quality and excellent performance.
You can use this spotting scope in most harsh environment too. It is built with an O-ring sealed to the optics which is to prevent moisture, dust and even debris to stick onto the optic. The O-ring seal will also result in waterproof performance
Not like any other spotting scope, this scope is filled with argon gas to inhibit internal fogging effectively as you bring it out to different terrain.
To discuss a bit about the accessories, the Vortex Razor HD spotting scope can be equipped even with smaller tripods. You should also be careful with the strap because you can easily lose your grip on the scope allowing it to slip off.
If you are planning to participate in any serious event such as an Olympic tournament in archery, this would be the perfect spotting scope for you!
To conclude, this is one of the best spotting scope that will deliver a level of optical quality and even resolution unmatched by many of its peers. Not the mention the great color fidelity. As for this HD spotting scope, you can definitely hope for distortion-free images, augmented light transmission, increased resolutions with outstanding accuracy and color contrast which makes this spotting scope almost irresistible.
As a bonus, the Vortex Optics also provide VIP Unconditional Lifetime Warranty! No need to worry about spoiling the scope. This "Very Important Promise" to you will make sure that you are taken care of with unlimited lifetime warranty which is fully transferable. You will not have any warranty card to fill out while no receipts are required to change the product, all you have to do is just to contact Vortex Optics. Even so, it is important to note that the VIP warranty will not cover the loss of product, theft, deliberate damage or even cosmetic damage. All of these damages will not reduce the performance of this product.
Mar 10, 2018 | The Optics
What are the features of Barska spotting scope?
The BARSKA Spotting Scope is flexible to use and accurate for any outdoor activity. It's a so much useful for birding and hunting both.
Here are some of the features of Barska spotting scope:-
1 Powerful Spotting Scope
2 Flexible to Use
3 Focus and Optics
4 Durable
5 Fully Multi-Coated
6 Straight Eyepiece system
If you want more details you can also check The best Spotting Scope Review 2018 and make your own decision.
Dec 08, 2017 | The Optics
Loose internal lens
Mar 16, 2009 | Optics
Feb 23, 2008 | Fujinon Super 80 (25x80 mm)
Middleton, WI 53562
Jan 25, 2008 | Fujinon Super 60S
Optics Logo
Top Kowa Optics Experts
james laughton
james laughton
ray gallant
Are you a Kowa Optic Expert? Answer questions, earn points and help others
