Wiring diagram for lennox whisper heat model g2002e-75-2
5 Suggested Answers
  • 70 Answers
SOURCE: need a wiring diagram for
Are you sure the modle # is good?Cant find any thing?
Posted on Aug 28, 2010
  • 85 Answers
SOURCE: NEED WIRING DIAGRAM FOR WISPER
http://hvacpartsshop.net/G20_Series.pdf This should be what your looking for.
Posted on Dec 09, 2008
  • 340 Answers
SOURCE: How can I determine the age on my hvac system?
need the serial ##
Posted on Jun 23, 2009
  • 4736 Answers
SOURCE: What is the energy effeciency
The A.F.U.E. rating on the G20 series is a paltry 77%. Compared to 94% A.F.U.E. on the high efficient models.
Hope this answered your question. If it did, I'd appreciate you rating my response.
Posted on Apr 05, 2011
I installed a new thermostat on my hvac system and the heat is not working anymore.
On that thermostat there is an R and an RC wire connection, the R is the power wire for heat and RC is the power wire for cooling. If you connected the power wire (normally red in color) to the RC only the fan control and AC control will work, there has to be a jumper wire between the R and RC terminals (assuming there is only one control transformer) for both the heat and cool functions to work.
Jan 21, 2014 | Honeywell Programmable Thermostat Heater
Lennox whisper heat gas furnace blows cold air,
As others have said, furnaces require a lot of maintenance. It sounds like a number of things could be causing the problems you've had. A professional would likely be able to pin point the problem and get it fixed.
John Cribbs ' Heating Maintenance Services Salt Lake City UT
Nov 13, 2012 | Heating & Cooling
What is the energy effeciency rating on the Lennox Whisper Heat, G20 series?
Apr 05, 2011 | Heating & Cooling
I have a Lennox elite series furnace. The vents are just blow out cold air, not heat. The theromstat is now working strange. I set the digital theromstat at 75 deg. and then place the thermostat on hold....
You did great! Yes you have a heating system error not a thermostat issue. The 2 blinking lights is an indication something is wrong. Now what you need to do is to remove one of the panels on the heating system and look for a wiring diagram pasted on the reverse. On this diagram there will be a diagnostic chart explaining where to start looking for an issue based on 2 blinks. Because each model is different, a 2 blink error code could indicate a bad pressure switch, plugged air filter or any other thing.
Mar 21, 2010 | Heating & Cooling
I am trying to change Lennox to Honeywell
Just remember what wires went to which terminal. Usually color coded, red =R, white = W, etc, Shouldn't be too hard. Let me know if you run into a problem.
Jan 02, 2010 | Honeywell Electronic Programmable...
Lennox furnace not heating up
sounds like the ignitor is bad. there shoule be a 2 wire plug going to it. after the inducer motor starts, you can check the voltage at the 2 wire plug located under the burners. you can unpug it to check voltage or you can probe the back side of the plug with a volt meter. if you are getting 120v but it is not glowing, it is bad. you can also ohm it out while it is off.
Feb 02, 2009 | Heating & Cooling
Heating & Cooling Logo
457 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
