Question about Plumbing
How to replace check valve on Pegasus kitchen faucet?
Received replacement check valve, but cannot figure out how to remove the old one. Would rather not remove the whole assembly to get to it. Thanks.
  • 9 Answers
SOURCE: kitchen faucet Remove
All faucets have a hot and cold line input. The single handle units have a mixing valve within the handle. Aside from removing the water lines there is usually some type of connecting bolts for the base plate as well that will need to be removed prior to removing the faucet. Do not forget to turn the shut off valves off at the wall before you remove the water lines.
Good Luck
Posted on Dec 04, 2008
  • 659 Answers
SOURCE: Replace valve in grohe kitchen faucet
If you could take a closeup picture of the valve and faucet, I can guide you step by step. Just email me at newairac@sbcglobal.net. Without seeing what you are looking at and working on, it would be hard because there are so many different styles and brands and each are unique.
Posted on Mar 23, 2009
SOURCE: Replacing Cartridge Valve in Kitchen Faucet
A little WD-40 was all it took, although it was quite difficult to remove using lock wrench pliars.
Posted on Sep 15, 2009
bearsfan7538
  • 119 Answers
SOURCE: Trying to fix leak on kohler fairfax kitchen
You need to remove handle and cartridge and spout should come off to replace the rest very common leak
Posted on Nov 15, 2009
canddplumb
  • 35 Answers
SOURCE: How to repair a pegasus faucet
I was unable to aquire a spec sheeet. I didnt know the model# or name.I did find a web site that had pegasus fausets.Fausets.com I tried to down lode the specs on 1 of there fausets.They wouldnt let me.But i did get you a customer service#1800-444-5783 .I hope this helps
Posted on Dec 02, 2009
How to remove a single hole kitchen faucet
There are shut off valves inside the cabinet under the faucet. Shut off the valves and open the faucet to relieve the water pressure in the line. Loosen the lock nut that is behind the sink directly under the faucet and unscrew the water lines. Next step is to lift up the faucet from the cabinet. Reverse the process to install a new faucet.
Aug 07, 2014 | Pegasus Technologies Plumbing
HOT AND COLD WATER STOPPED COMING OUT OF OUR KITCHEN FAUCET
Do you get water when you disconnect hose from the faucet? If so, perhaps plastic backflow preventor in the faucet is stuck?
May 29, 2012 | Pegasus Technologies Plumbing
My Pegasus kitchen faucet leaks at the top, even when off. I'm not sure which model, it has one handle with a side spray. What do I do.
Turn off water supply to sink. Wrap top of goose neck with rag and use a pipe wrench to remove ( lefty loosey, righty tighty). Inspect interior of faucet for worn o - ring or gasket and take damaged part to local hardware store for replacement parts. The gasket or o - ring may be on the gooseneck ( the part the water comes out of between the handles or below a single handle faucet).
Good luck!!
Nov 29, 2010 | Pegasus Technologies Plumbing
Dec 02, 2009 | California Faucets 1/2" Thermostatic Valve...
No water pressure on Pegasus kitchen single handle faucet
Those new faucets generally have a lower water pressure due to legislation passed in 2007 that reduced that maximum allowable gpm (gallons per minute). I hate to tell anyone this but there is little if anything you can do. First of all, make sure the shut-off valves are open completely. I know that sounds elementary but I've seen it a bunch of times.
Also check to see if the aerator is blocked with a bit of debris.....unlikely if the flow is uniform but still an easy fix.
Hope I didn't break your spirit too much....
Apr 28, 2009 | Pegasus Technologies Pegasus F1225100BN...
No water pressure in kitchen sink. Not the aerator.
First of all we like to check the easy/cheap things first.
1. Are the shut-off valves closed lightly?
If they are closed, open them.....easiest fix of them all.
2. If the valves are open then possibly a washer is shifted.
Turn off the water supply at the valves under the sink. Remove the handles by removing the set screw under the handles. There should then be a packing nut which holds all of the "guts" of the faucet in. Remove this nut and pull out the long stem. On the bottom of this stem is a flat washer that may have been damaged or is just slightly shifted. EIther way, I would replace it if the faucet is more then a few years old as it is cheap and you already have access to it. WHen replacing the valve stem, be sure to use a plumbers grease on all rings and seals. The rest of the replacement is the same are the removal.
Hope this helps.
Apr 25, 2009 | Price Pfister Marielle Kitchen Faucet with...
Single handle pegasus kitchen faucet. No water pressure when turn
Kitchen faucet? Remove the internal parts and check for blockages.
Apr 05, 2009 | Pegasus Technologies Pegasus F1225100BN...
Plumbing Logo
287 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
