Replace coleman furnace ignitor - Heating & Cooling
  • stillkikkin2 Apr 11, 2009
    I have a coleman furnace DGAT56 in my 1997 mobile home. The furnace would kick on but then it would shut down before kicking on the heat. The inducer was bad and blower control board. The oem booster and oem p c board were replaced on Christmas Eve. It cost me almost $600 and now it is doing the same thing. Is there anyway to light that burner. Like when the ignition on a stove if it doesn't work you can light with a match. I have been withoutt heat for a week now, thank goodness it is not freezzing weather. Thanks Judy
    Novelist:
  • 124 Answers
YES
Posted on Oct 25, 2008
05-32 automatic ignition system not lighting
if voltage to ignitor bad ignitor if no voltage to ignitor bad fenwal
Feb 19, 2013 | Coleman Fenwal Gas Furnace Control Circuit...
I have a coleman evcon furnace Model BGU075. sometimes the automatic ignitor comes on but the furnace won't light
Check your gas flow...clean the sensor...and be sure your gas switch is in the right pposition
Nov 20, 2010 | Coleman Heating & Cooling
How to replace ignitor on coleman furnac evcon model dgato70bdc i have a new ign and i need to know how much of the front of the furnace i need to remove or what part of the front to remove, the gas valve...
Hi some of these you do not have to remove the burner you just indo the hot surface ignitor its black with ceramic base ? if so you remove the metal cover over the burner and swap it out .
Feb 04, 2010 | Heating & Cooling
Using alot of hot surface ignitors
don't touch the surface of the igniter when handling it, and don't bind the mounting bracket when you tighten the capscrews, the bracket and igniter should be firm and no loose/movement if you try to move the bracket. also make sure the igniter is going back off after the burners light
Feb 28, 2009 | Tools & Hardware - Others
Ignition failure. Relatively new furnace - under 5 years old.
You can replace a hot surface ignitor if you are careful not to touch the silicon surface. The oil from your hand may cause the ignitor to fail. make sure to turn off electric supply before attempting. You will probably need an OEM (from a coleman dealer) ignitor.
Usually best to bring the old one with you to make sure you get the right one with the right wire terminals. Or you can wire nut a new one to the old terminals. Could also be a dirty flame sense rod.
Hope this helps.
Matt
Dec 28, 2008 | Coleman Propane Forced Air Heater...
Have to replace ignitor on coleman furnace every year
The voltage regulator on the control module is sending the wrong voltage to the ignitor or the ignitor is getting wet from condensation. That ignitor should last many years. Replace the control module.
Dec 04, 2008 | Heating & Cooling
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
