Question about Magic Chef Kitchen Ranges
The left front heating element in my Magic Chef Stove is not heating.
  • cliffselby Nov 02, 2008
    I don't know how to get into the Magic Chef range to get at the defective electric heating element.
  • cliffselby Nov 03, 2008
    The Magic Chef Range with a defective heating element at left front which I do not know how to get to is Model 3889VRA.
  • 535 Answers
See the hitting coil of your stove is bed or damged so change it or see the relay of your coil if u have not proper idea how to chak it then go with a professiol repairer
Posted on Nov 02, 2008
    Genius:
  • 1,124 Answers
Could related to the oven control or the heating element. Which is your Magic Chef Stove model number?
Posted on Oct 24, 2008
    Genius:
  • 1,550 Answers
You need to have a check over these
  • Loose wiring connections at the ignitor, the grounding strap, or spark module.
  • Broken or pinched ignitor wire between the burner and module
    Brigadier General:
  • 6,966 Answers
If your concern is with only one of several, then possible culprits could be:
  • the heating element;
  • the switch.
Both of the above could be tested with a continuity tester.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Oct 24, 2008
    It would be to your advantage to postback the exact model number that more details be made available.
  • Louie  Role
    Louie Role Nov 06, 2008
    Due to regional variations in design and manufacturing, some of the steps may differ slightly. To replace a defective heating element, please follow below procedures:
    • Before anything, pls make sure that the power to the Magic Chef Kitchen Range is off either at the circuit breaker or unplug from the mains;
    • Raise the cooktop. To do this, on some versions/models, the retaining trim must be removed by removing the retaining screws under the front edge of the cooktop;
    • Raise the cooktop;
    • the heating elements would now be exposed;
    • unplug the element's wiring harness. It is a good idea to mark the wires where they are connected or draw a connection diagram;
    • The entire cooktop could now be removed;
    • place the cooktop upside down on a flat surface padded with a blanket or rags to avoid scratching the cooktop;
    • Remove the defective element by undoing the screws holding the element mounting bracket to the cooktop;
    • turn over the element assembly to gain access to the temperature limiter and element;
    • Normally, the element is encased in a fragile insulated casting;
    • remove the wires from the element (again making a wiring diagram would be helpful);
    • Remove and replace the defective element and limiter by undoing the screws holding the element to its bracket;
    • lift away from the bracket. Install the new element and limiter assembly by reversing the dismantling steps;
    • Please make sure the new element is flat against the underside of the cooktop in the correct position;
    • Ensure that the element's wires are returned to the correct terminals/connectors.
    • Plug in the element's wiring harness;
    • close the cooktop and replace any retaining screws.
    Usually, a replacement element wold also have an instructions sheet (16000542) for a more appropriate procedure for your particular version/model.
    Genius:
  • 1,847 Answers
Are you getting any fault codes? Check this relay board for coil voltage when the unit shuts down by itself. If the voltage is on the coil but not at the element, this relay board is bad.
  • Legin Varghese
    Legin Varghese Oct 24, 2008
    The relay board is controlled by the clock control.
    Does the clock display any codes?
I have a magic chef stove which has three prong and I just bought a he spectra glass top which it has four prongs could I use the three prong power cord on the glass top
tes you can use 3 prong the left and right wires go on left and right terminals on stove middle wire goes in the middle.
May 14, 2016 | Magic Chef Dryers
Oven element does not heat up
Ok
1) does the clock come on
2) do the surface burners come on
if you have the clock (so power is getting in, but you can't get any thing to heat up.
You will need to test the outlet it is plugged into. You should be reading 110 from both the left and right sides of the outlet (totaling 220 ac) if you only get it from one side then the problem is in the wiring, and causing the stove to try and run on half the current it needs.
Oct 18, 2014 | Magic Chef 9815 Electric Single Oven
HOW DO I REMOVE THE LOWER ELEMENT OF A MAGIC CHEF STOVE OVEN
What is the complete model number of your unit? Look inside the door area.
Nov 28, 2012 | Magic Chef Kitchen Ranges
I live in a rental and tired to cook a chicken,some greese hit the coil burner in botton.I was standing in front when it had a flash fire out from between the door and the drawer.Is this a flaw in this...
That is to be expected when grease hits a heating element, just be cautious and always remember to use flour on a grease fire, not water.
May 30, 2011 | Ovens
Magic chef gas stove
i searched and never got one . so my solution is not to use the stove and be creative how i make suppers. so that is how i fixed it. do without and go on.
Jan 14, 2009 | Magic Chef CGR1420 Gas Kitchen Range
What is age span of stove?
I was using a 1938 model in an apartment unit and only replace it for the looks. Electric heating elements are cheap and relitively reliable..
Jan 02, 2009 | Magic Chef Ovens
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
Magic Chef 6551WUW Oven
is the element still in one piece and mostly smooth to the touch? if you find any part of the element very rough where it looks like it actually melted then you've found your problem. post an update if this doesn't solve the problem.
Nov 01, 2007 | Ovens
Kitchen Ranges Logo
60 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
