Question about KitchenAid KSCS25IN Side by Side Refrigerator
How do you remove the light shield and replace the light bulb?
Cannot figure out how to remove light shield in the upper/top section of refrigerator. What is the secret?
How do I replace the lights in my freezer
Turn off the power to the refrigerator/freezer by flipping the appropriate switch in your breaker panel. Alternatively, unplug the refrigerator from the wall outlet.
Open the freezer door. Remove any items from the shelf directly under the light shield, then remove the shelf.
Press down on the top, front edge of the light shield until the locking tabs slip out of the slots. Swivel the light shield downward slightly to release it. Pull the shield out of the freezer compartment and set it aside.
Turn the light bulb counterclockwise to remove it. Insert the GE replacement bulb into the light socket and twist it clockwise.
5
Reattach the light shield by sliding it into place. Gently push the tabs into the original slots.
6
Insert the shelf into the freezer and reload it with the frozen food removed earlier.
7
Close the freezer door. Restore power to the refrigerator by flipping on the breaker or plugging it into the wall outlet.
Jul 25, 2017 | Freezers
Replace bulb in refrig compartment of model TFX25JRYF_WW
Hello Brenda;
My name is Peter. I am a retired field service refrigeration technician.
First, This is a special bulb. You can obtain the bulb in your local supermarket. They are a little more expensive than household bulbs.
To remove your light bulb shield, pull down on the bottom of the shield, pull towards you and lift up.
Dec 02, 2014 | GE Refrigerators
On sub zero 690 like to change bulb in lighted electronic control panel
you will have to remove the light shield, remove the plastic trim that says the model number in front of the light shield, then the 2 screws holding the side cover on the left side of the fridge section. Then the cover will need to be pushed towards the rear of the fridge then tipped out at the front. It has springs holding it in the back.That should access the bulb you need to change
Nov 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
Light went out on refrigerator side
Your Sub-Zero unit contains standard 40 watt appliance bulbs in all compartments.
You'll need to remove the light shield in the top of the refrigerator or freezer to replace the bulbs. Place your hands under the light shield and release the two clips on the back of the light shield, then lift up and slide back slowly until the key slots on the side of the light shield drop past the mounting studs in the side walls. Then remove the shield.
The bulbs are now accessible.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 27, 2011 | Sub-Zero 690 Side by Side Refrigerator
Water leaking from ceiling behind light bulb near water filter in Frigidaire side by side FRS26LF8CS1
On your model the freezer is over the fresh food section and defrost coms about every eight hours. If by chance your condensate drain from freezer above becomes blocked behind that light shield the water from defrost will collect in a cup behind that shield and flow down into the fresh food section. Click Here=> Leaking Refrigerators and once done there click here=> Leaking Refrigerators, Just What May Be Happening If you have any questions about your Refrigerator I will be here or reachable here, Thanks and please rate if helpful, Sea Breeze
Oct 18, 2011 | Hotpoint HTS16HBR Top Freezer Refrigerator
How to change the light bulb
Hi
Not all bulbs will fit your refrigerator. Be sure to replace the bulb with one of the same size, shape and wattage. On some models, the dispenser light requires a heavy duty 10-watt bulb. All other lights require a 40-watt bulb.
1. Unplug or disconnect power from your refrigerator.
2. Remove light shield when applicable.
NOTE: To clean the ligt shield, wash it with warm water and liquid detergent. Be sure to dry the shield thoroughly before installing.
3. Remove the light bulb and replace it with the same size, shape and wattage.
4. Replace light shield when applicable.
Also check this link bellow:-
http://whirlpool.custhelp.com/app/answers/detail/a_id/1403
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 02, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Hi - hearing a fan whirling sound when either of the upper doors are closed. Freezer is still freezing but warm up top. Pressing the close button instead of closing the door produces the same fan sound.
Make sure the lights are going off in the freshfood section. If lights staying on remove bulbs immediately and order new control board located on back of unit.
Mar 12, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
Replacing the hole headlight
SECTION 417-01: Exterior Lighting 2002 Lincoln LS Workshop Manual REMOVAL AND INSTALLATION Lamp Assembly —Headlamp Removal and Installation
s2x~us~en~file=ani_caut.gif~gen~ref.gif WARNING: The halogen fog lamp bulb contains gas under pressure. The bulb may shatter if the glass envelope is scratched or if the bulb is dropped. Handle the bulb only by its base. Avoid touching the glass envelope.
NOTE: The headlamp bulb should not be removed from the headlamp assembly until just before a replacement bulb is installed. Removing the bolt for an extended period of time may affect headlamp bulb performance. Contaminants may enter the headlamp assembly where they can settle on the lens and reflector. Never turn on the headlamps with the bulb removed.
  1. NOTE: Make sure that the headlamp switch and the ignition switch are in the OFF position.
    Release the ambient air temperature sensor.
  1. Remove the radiator grille opening cover at the top shelf of the bumper.
  1. Remove the radiator upper sight shield.
    1. Remove the pin-type retainers.
  1. Position the headlamp assembly for removal.
    1. Remove the three bolts.
    • Disconnect the electrical connectors and remove the headlamp assembly.
  1. To install, reverse the removal procedure.
    • If necessary, install new bulbs.
Feb 27, 2010 | 2002 Lincoln LS
I need to replace the adaptive Defrost Control Board on Maytag Refrigerator Model No. MZD2766GEQ. Where is this board located?
Its Located in the top right inside corner of the refrigerator section near the back wall & to the right of the water filter.Its tough to get out but only takes about 10 minutes to replace the part
Nov 18, 2009 | Maytag MSD2756G Side by Side Refrigerator
KitchenAid KSCS25IN Side by Side Refrigerator Logo
207 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
