Question about Sony HT-CT150 Theater System
Sony CT150 low volume
Works fine except you can barely hear it. Set volume to MAX and still is very quiet. Cannot get volume to a listenable level.
5 Suggested Answers
SOURCE: System works great with dvd, radio, and ipod dock.
It sounds like either the input selected to the receiver is wrong, the wires are not hooked up correctly, or the wires are bad. What type of connection are you using-RCA jacks, DVi connector, etc?
Posted on Jul 15, 2009
shahabdun
  • 249 Answers
SOURCE: Volume issues
The connections are inappropriate.re check the cable connections.
Posted on Jul 05, 2009
  • 308 Answers
SOURCE: I have the Sony ht-sf1000
Check the settings sometimes there is a setting to mute output volume by 10db, 20db, etc.
Posted on Jun 10, 2011
  • 1702 Answers
SOURCE: When I turn on my
Hi, Sounds like Speakers are not connected properly. + to+ - to - Right to right left to left.
Good luck.
Posted on Jun 12, 2011
Low volume on incoming calls
remove battery from phone and reinstall after 10 mins... this seems to fix alot of things also go to sound setting a make sure the volume is turned up all the way
Jul 09, 2012 | Apple iPhone 3G
Cant hear people when they call
Yes you are very correct. Its a earpiece problem. I use to have a Sony Ericsson K750i and the earpiece is not loud at all, so when I changed the earpiece, it began to work perfectly again. So I'll support or advice that you change the earpiece.
Take care.
Nov 19, 2009 | Sony Ericsson Walkman® W995 Cell Phone
Old turntable works but is too quiet to hear
It sound like you may have to hook your turntable up to a phono input. Turntables have low level outputs. The phono input is designed to amplify this low level more than the cd/dvd inputs do. If you do not have a phono input, you can buy an external "phono preamp" online. Hope this helps.
Aug 04, 2009 | Audio Players & Recorders
Low volume
You can use a FM modulator and hear it fine through your radio, but then you have the problem of no radio to listen to.........Im lost too.
Jun 23, 2008 | Sanyo NVM-4050 GPS Receiver
Plantronics GN9120 microphone is too quiet for listener
I've had this same probelm and after much pressing of buttons eventualy fixed it by reading the manual... :s
Last page page of Quick Set-Up Guide under "Transmit volume adjustment":
1.) Make call to another phone user to assist.
2.) Press + and - on the headset at the same time.
3.) Adjust volume by pressing either - and +.
4.) Confirm volume with helper.
5.) Wait for 10secs and the settings will store.
May 08, 2008 | GN Netcom GN 9120 Professional Headset
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
Sony ericsson Z520
I had the same problem with that phone... while manipulating the mobile part (cover) you can slightly improve the volume.
Another point to check is the button on the side of the phone which allows to increase or lower the volume: it could happen that you turn the volume low without noticing it...
My solution was to replace the phone.
Jan 02, 2008 | Sony Ericsson Z520a Cellular Phone
Was working at first but now sound is too quiet
check mic level on recording mixer for windows N.B. r-mixer different from playback-mixer
Apr 05, 2007 | Sony FV100 Consumer Microphone
Audio fade
if there is no problem with the surround sound, you have a problem with the volume regulation circuit or with the main amp of this TV set, But to say the least is you have a backup to fix your problem, with the sound system, you said it works fine. this could run ya about 250 to 400 to repair. Good luck.
Mar 29, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Sony HT-CT150 Theater System Logo
173 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
