Question about Kenmore Ovens
Model number 790.95660102
Message F1 flashing
An f1 error is flashing and my oven door glass is cracked top and bottom. Can this be fixed?
OF course if they still make that models glass check the link http://www.searsrepairparts.com/ you will need model number handy .
Nov 27, 2015 | Kenmore Ovens
F1 code
Most F1 error codes refer to a communication error in the main control board/ clock on some there are reset overload switches that if tripped show as a push button that is pushed outward that you can reset. This also mainly depends on which type of oven that you do have and you would have to provide the make and the model number of the unit in order for me to give you an exact solution to your f1 error instead of a generalized one. Sometimes also you can turn off the power at your electrical breaker for 7 minutes which this causes the control to reset in some. Most of the time in most models though the F1 refers to having to replace the electronic control module (ECM. If you have any further questions or wish for me to look up the exact error for your unit message me back your make and model number and I will give further diagnosis on your unit. Thank you again
Rick
Nov 26, 2011 | Ovens
Have problem with Maytag CWE 9000 the beeper keeps going off even after you press cancel Code is F1, any idea
likely the problem is a bad control board, aka a clock/timer. Usually F1 error codes do refer to main board or main control error in which you would have to replace the control. You can also try shutting off the breaker for 7 minutes which sometimes does make the control reset but this only works maybe 10 percent of the time due to the F1 error code. If you need the part number of the control message me back your full model number and serial number as well.
Thank you
Rick
Nov 19, 2011 | Ovens
Old Magic Chef wall oven (model 9875-5XRB), constantly beeps and displays the F1 error code. I have replaced the touch pad once before. Is that the only solution?
Does anyone know the answer? This was posted in October 2010! I ran the self clean too about a week ago. But we had a bunch of power outages last night. Today my oven has taken to beeping and flashing the F1 code. It is almost the same Model number. they wrote 9875XRB (not 5XRB) ...
Oct 18, 2010 | Ovens
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Error Code -F1- and Broken glass door
Welcome to fixya.com f- 1 is the electronic key pad a key is stuck and usually you will need to replace the key pad site to obtain parts is partsselect.com but before you do disconnect power to unit for 15 min then re connect power to see if unit reset its self. And at Parts select.com you can order the glass you need, Regards, Lee Davidian
Apr 19, 2010 | GE Profile JTP56 Electric Double Oven
F1 message flashing, annoying beep in the middle of the night
you could have a bad touch pad or ECU which is the main control board.
Sep 16, 2009 | Amana AOCS3040 Electric Single Oven
What does the message F1 mean on my Kenmore range?
This probably means the electronic control board has failed. Can you find another model number on the unit? It may be on a metal plate inside the door. This way I can be sure that I'm looking at the correct fault code table.
Jan 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F1 error message on kenmore gas range
The F1 usually means a problem with the touchpanel. It is also related to the F7 problem. I have developed a fix which may solve you problem. Please go to the following link for my fix.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my fix with over two thousand unhappy GE customers. Most report success. Please let me know if this works for you too. I am making a statistical study of this problem.
Regards,
Powerman
hutchipop@yahoo.com
Dec 05, 2008 | Kenmore Ovens
Ovens Logo
59 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
