Question about Rapid Air Compressor Manifold
Power system plus 1110C broken manifold or replacement
BIOS PASSWORD FOR A MINI 1110C ACER NOTEBOOK
It is what was set by the administrator or the person who set it up.
Mar 03, 2016 | Acer Computers & Internet
My nokia 1110c phone sms not come to inbox what i do
you have to delete some sms, the phone memory is full, delete old sms, you will see the new.
Jun 20, 2015 | Nokia 1110 Cellular Phone
How much it cost to fix the intake manifold for chevy uplander
It would all depend on the problem, if the intake is broken and needs to be replaced I would think it would be the cost of the part along with the labor to change it plus materials like fluids, gaskets, and sealers.
Jul 26, 2014 | Cars & Trucks
My exhaust is coming out at the front of the car not the rear
Do you mean broken off and stuck inside or broken off and fallen out? Broken off and fallen out in this case is a good thing. Sounds like you mean the exhaust is broken at the manifold but what isn't clear is which piece, the manifold or the exhaust pipe. The manifold is a part of the engine, the exhaust pipe is connected to the manifold via the flange you speak of so if it is broken (coming from the engine as a base point) before the flange you need to change the manifold (less likely - hardly ever breaks - usually made of cast iron or cast aluminium) or where they typically break just after the flange (exhaust pipes are notorious for rusting out here, you will need to replace the front exhaust pipe and donut (gasket within the flange). Due to the high heat in this area it is extremely common for the bolts holding the pipe to the manifold to not just be ceased to it (lube will probably do no good) but to actually weld (or forge if you will) themselves to the metal of the pipe, in which case you need to cut them out with a torch. A good mechanic can usually do this without damaging the manifold. That is why it is a good thing if they have broken off and fallen out, much easier to change then welded in bolts (which would not fall out). I say replace the front exhaust pipe because without knowing which year your protege is or if it has an after market exhaust I don't know for sure if it is a one piece system or more than one piece. If it is a one piece you will need to either change the whole thing or do some cutting and welding to piece a section in. In which case, I do not recommend cutting the new piece you purchase but if the old exhaust on the vehicle is in alright shape from the muffler back you may be able to section it off and just replace the front section. Piecing it together would require at least one more piece, one to contact the old pipe to the new which would also need to be welded on but this method can still be cheaper (most of the time). Anything other than a simple in/out replacement will require torches and obviously if the bolts are welded in it is not a simple in/out job.
Mar 25, 2014 | Mazda Protege Cars & Trucks
Our pool is green, the water seems to be bypassing the filter cartridges. Trying to figure our what could be broken to get this working properly again?
You may have a broken manifold. That's the part at the bottom of the tank where the filters set down on.With the filters out and the tank empty, fill the manifold with water. The water should stay put indefinitely. I the water level drops, you need to replace the manifold because even if the crack looks small. under working pressure in will open up and allow most of the water to bypass the filters altogether.
Aug 22, 2013 | Pentair Clean Clear Plus Ccp420 Pool...
Broken intake manifold bolt 2004 escape
Remove the manifold and send it out to a machine shop, they can remove repair this broken bolt. Cost about $50.00
Jun 14, 2012 | 2004 Ford Escape
UST Power System Plus 1110c. Broken valve, no online help or diagrams. Need to remove the pressure gauge assembly, but after a few turns, it stops and won't come off.
I have a similar problem. The cheapo valve broke off when I was moving the compressor and can't find a replacement. UGHHH this is why you should go with POrter Cable or Dewal, off brand **** is getting annoying.
Nov 22, 2010 | Air Tools & Compressors
Locating & replacing the MAP sensor in a 2000 Saturn SL-1
CODE PO133 IS HO2S - 11 BANK 1 SENSOR 1 SLOW RESPONSE CONDITIONS. POSSIBLE CAUSES THE EXHAUST LEAK PRESENT IN THE EXHAUST MANIFOLD OR PIPES.FUEL SYSTEM IS TOO RICH.FUEL PRESSURE TOO HIGH FUEL PRESSURE REGULATOR LEAKING OR ONE OR MORE FUEL INJECTORS.STICKING LEAKING.HO2S ELEMENT IS SILICON WATER OR FUEL CONTAMINATED OR IT FAILED.TP SENSOR ELEMENT BROKEN.CAN CAUSE FALSE ACCELERATION EVENT.OR THE PCM HAS FAILED.
Jan 12, 2010 | 2000 Saturn SL
I want to unlock my nokia 1110c
Hello.
You can go to http://www.mobileunlocked.com/mobile_unlocking.php
Sep 18, 2009 | Nokia 1110 Cellular Phone
Strange noise!
My 2005 GMC 2500HD (8.1 lt) had the same problem. I just had an exhaust leak fixed today. The right front manifold bolts were broken and the manifold was warped. The repair was 6.5 hours labour plus gaskets, seals, bolts and the manifold machining (parts were $130 CDN).
Jul 08, 2008 | 2002 GMC Sierra 2500HD
Rapid Air Compressor Manifold Logo
135 people viewed this question
Top Rapid Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Rapid Air Tool and Compressor Expert? Answer questions, earn points and help others
