Question about Sony WEGA KE-42TS2 42 in. HD-Ready Plasma Television
Thin Black lines going down my screen, sony Wega Ke-42TS2
I have a sony Wega Ke-42TS2 and there are about 10/15 black lines going down the screen. It appeared when we came back from holidays. They're very thin and in the beginning they were flicking on and off, and where changing from white to black. But they're perment now. They are bunched together aswell with all lines spanning about 2 inches across the tv. It kinda looks like someone bent the screen, like the winkles along the spine of a book. Any help would be nice. Thanks
    President:
  • 3,130 Answers
These sets are common for bad connections on the ribbon cables connecting the screen to the drive printed circuit board. Or the drive circuit could have a bad drive scan IC. I doubt that but possible. Your going to need to call an AUTHORIZED sony repair servicer to trouble shoot this for you cause any other shop may not have a clue of this problem. Good Luck
Posted on Aug 09, 2006
Sony Bravia Kdl-32nx503 thin black horizontal line on TV screen
T'Con board fault. Contact the authorized service centre for Sony. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 16, 2014 | Sony Televison & Video
Sony wega kde-61xbr950
Can be a problem with a misplaced connection, more likely the Ysus card to be replaced.
Aug 30, 2008 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
Thin white horizontal lines!!! I've had my WEGA KE-42M1 for 5 years with no problems until about three months ago. After about an hour being on, there are thin white horizontal lines that move randomly...
Sounds like your TV is giving out, plain and simple.
If this doesn't sound right, then only one thing comes to mind. Have you moved the TV recently? Are you using a different coax cable, (if using cable that is). If so, just change the cable back to the previous one and you should be fine.
Aug 21, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Blue line at bottom of TV Screen
Check out the Sony Websites. They extended warranties on their Rear Projection TV's. I came across this website
http://sites.google.com/site/sonylcdrptvproblems/sonyrearprojectionlcdtv-opticalblock#TOC-Summary-of-Sony-warranty-extensions
If you bought your TV in Canada, check out their e-support website/news bulletin
Dec 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KV-27FS200 bright horizontal line problem
try to replace all filter capacitor on vertical section area that can solve your problem.
Mar 07, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony WEGA KE-37XS910
This TV has a very expensive panel... we are talking $3000 core charge alone! It comes complete with all the lower buffer boards (which from the sound of it, you are having a problem with). Individual boards for this defect are not available on repair parts list I know of. A panel is what you need, PN: 9-885-063-33
Aug 17, 2008 | Sony WEGA KE-37XS910 37 in. HD-Ready...
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Vertical line black or out
Hello, The line appearing on your screen is probably the result of a connection problem on one of the address buffers located on the top and bottom section of the panel. These buffers feed the data signal to the panel to "address" which pixels should light and for how long. The other cause would be a bad display panel in which case the entire panel would have to be replaced, this is normally NOT the case. I hope this helps you. Good Luck. Joe Weibel CustomElectronics.Org
Dec 04, 2006 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
Sony 42" Plasma TV
this tv fail from loose ribon cable plug, but I dont recomend you to work with it, becouse you cand spoil and easy job for the tech, and will cost you more, so get a tech, will be better...good luck
Aug 09, 2006 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Sony WEGA KE-42TS2 42 in. HD-Ready Plasma Television Logo
296 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
