Question about Compaq Presario CQ5700F PC
What is script file "C.\system.sav\Util\TDC\Lhidecmd.vbs:
Windows Script Host can noy find script file "C.\system.sav\Util\TDC\Lhidecmd.vbs"
4 Suggested Answers
SOURCE: can not find Script file '' c:WINDOWSsystem32virus
format the pc
Posted on May 26, 2010
Testimonial: "thanks a lot."
  • 263 Answers
SOURCE: what can i do to my hard drives because they not open, when i tried to open my h
you can do a restor point just go back to last good know configuration or like a month before that happends
Posted on Dec 31, 2007
SteveRand
  • 210 Answers
Make or download a virus, then put it in that location.
But seriously: you don't need it, you don't want it, and you don't have it.
I have just bought a new Aspre One Notebook D270,
Jul 07, 2017 | Acer Computers & Internet
Tip
How to Encode your VBS and JS files for secure website uploading
If you are still at Service Pack 2 then you can use Microsoft's own Script Encoder download it from HERE it's a command line version so after you have installed it you need to run the command prompt also make sure the Windows Scripting Host is started.
REMEMBER MAKE YOUR SCRIPTS "FOR YOUR EYES ONLY"
For both Visual Basic Scripts and JavaScript you will need to format the text in your script to look like this;
Replace your code goes here with your actual code when the encoder has been run then you will see that the <SCRIPT LANGUAGE= ********> will have changed to <SCRIPT LANGUAGE= ********.encode> and your code will be random characters.
The Syntax for the encoder from the command prompt is;
Recognized file extensions are .js and .vbs, which are changed to .jse and .vbe, respectively, after encoding, also these type of files can be decoded if you know what you are doing and therefore not totally hacker proof.
IF YOU HAVE SERVICE PACK 3 installed then this won't work at all so the best method is to use this VBS2EXE this is also a command prompt program you must make sure that the script that you want to convert is in the same root folder.
When finished there will be a new file about 10 times larger then the script with the EXE file extension if you try to edit it all the code appears random this is the best method for encoding your scripts
If you want to do it ALL online and feel secure then you can do both VBS (VIsual Basic Script) and (JS) JavaScript using this website below but it is limited to 10kb per file
http://www.f2ko.de/ov2e/ov2e.html
If you create alot of batch files then I suggest that you also check out their BAT2EXE v1.5 this will convert CMD or BAT files into EXE files for web distribution you can also password protect and add a decompiler if required
on May 30, 2010 | Microsoft Windows XP Professional SP2
On startup cannot find script file 'cleanvirus.vbs'
May be you affected with a virus or missing some files...try to restore go to start /Accessories/System tools/System restore...try it
Feb 04, 2010 | Microsoft Windows XP Home Edition
My computer is not creating Restore Points... yes it's turned on... yes I know how to do a manual... but it disappears when the next Restore Point is created... can you help?
Creating a System Restore point using a shortcut For a more elegant way to create a System Restore point using Script in Windows Vista, check out our article Create System Restore Points Quickly using Script in Windows Vista and Windows XP.
Alternately, you may use the method below:
Copy the contents below to a Notepad document, and save it to a file name with .vbs extension (Example: createrp.vbs) and close Notepad.
set SRP = getobject("winmgmts:\\.\root\default:Systemrestore")
CSRP = SRP.createrestorepoint ("Created a Restore Point now", 0, 100)
If CSRP <> 0 then
Msgbox "Error " & CSRP & ": Unable to create System Restore point"
End if
Right-click on the Desktop and select New - Shortcut
Create a shortcut with the following target:
wscript.exe c:\scripts\createrp.vbs
Note: The above assumes that the createrp.vbs script is present in the c:\scripts folder. If that's not the case, change the Path accordingly.
Name the shortcut file name as Create Restore Point
Running the script To create a System Restore point, run the script with elevated mode. To do so, right-click on the newly created shortcut (Create Restore Point.lnk) and choose Run as administrator. When you are prompted for an administrator password or confirmation, type the password or provide confirmation. A System Restore point will automatically be created.
Nov 23, 2009 | Microsoft Windows Vista Home Premium with...
Can not find script file cleanvirus vbs
Can not Find. Script File
C:\WINDOWS\System32\CleanViirus.vbs
Oct 22, 2009 | Microsoft Windows XP Professional With...
Loadig script C WINDOWS System32 scvhost vbs
your svchost file is been couruted or damaged, get ur system formated by well qualified engineer and first antivirus installed.
Jun 20, 2009 | Computers & Internet
Error
try system restore
Jun 18, 2008 | Microsoft Windows XP Professional
Script file "c:\Documents and Setting\Quality\boot.vbs".
I guess this is a Startup item on your computer and you can easily remove this from your computer by going in to the registry. But, before that to make sure you can try disabling it from the system configuration utility..
In order to do that, click Start -> Run -> Msconfig -> Ok
Click Startup tab and look for the entry boot.vbs..
Simply clear the check box and restart the computer..
Lemme know the result.. if it works then i can assist you in removing it permanently.
Compaq Presario CQ5700F PC Logo
423 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
