Question about Delta & Single Handle Shower Faucet
Ihow do i positon the hot and cold mixing valve so i get get both hot and cold not just one side
I get hot or cold not a mixture of water that is confonfortable
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Change the cartridge
Posted on Mar 06, 2013
2 Suggested Answers
  • 81 Answers
SOURCE: Shower head drips. Single stem with handle for
There are answers to this question already posted here. work on your search words on Google
Posted on Oct 24, 2010
How to adjust Banner M580 Series faucet to provide a better hot/cold balance?
Could be a defective mixing valve or blockage in the cold water input line to the valve
Jul 26, 2016 | Banner Faucets Pro Series M580 Single...
Whirlpool Cabrio Platinum water is coming back out of the hot hose
You have a hot , cold and a mix valve ,I would suspect that the mix valve is stuck, try tapping on it
Whirlpool W10372095 Valve AppliancePartsPros com
May 26, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
There is a hot water valve & a cold water valve on the Dexter T300 machines but it is a 2 coil valve. does the hot water valve supply only hot water or does one side provide water to perhaps the...
supplies hot water when needed, cold water when needed. and then warm water when needed. so the second coil is for warm water. it basically mixes the hot and cold water.
Mar 17, 2011 | Washing Machines
Hello, Hot to very warm water comes out of the regular COLD water faucets throughout the house for about 45 seconds whenever the COLD water faucets are opened. I suspect that the thermostatic...
Yes the mixing valves do wear and give out........I had to put a micron filter in the input line to the hot water tank and solved the promlem for around 8 tears now. knock on wood....Hope this helps.
Aug 12, 2010 | Home
Possible Mixing valve Problem
I would pull the lines off the back and check the inlet filter on the hot and cold sides of the water inlet and clean the screen style filter. If you just use cold is the water cold if the cold water valve was bad then you would get no cold wate when set to cold.
Jan 20, 2010 | Maytag PAV2300 Top Load Washer
Hi,water at shower head not hot although hot side of valve is getting adequate supply must be mixing with to much cold however high temp is set on valve,Any tips,thanks
the valve where they mix is blocked on the hot side, or the shut off is almost shut off. check the shut off first.
Nov 13, 2009 | Home
Water is always hot
Turn off the water from your hot water valve at the wall. See if you get any hit water then. If you do it must be comming in from the cold water side. If you dont get any water to flow the water valve or selector switch is at fault.
Please rate me as high as you can and thsnks for using fixya.
May 10, 2009 | Washing Machines
Hot water first from faucet, two minutes later cold???
you could be having a problem elsewhere in house system! do you have a garden hose hooked up with a "Y" hose? or something in system were hot and cold connect...then a valve after? what happens is the hot water can back siphon through cold lines..its rare, but this happens, and is dangerous! water from hot water tank is full of bacteria, and if you drink it , well thats not good!
Mar 26, 2009 | Chicago Faucets CHICAGO FAUCET Mixing...
Scalding hot water
If your water is too hot, then either the water tank thermostat or the wiring to the indoor unit is defective. When the water reaches the set temperature, then the tank thermostat contacts should open up and shut off the combustion unit. If the combustion unit does not shut off, then check all wiring and relays. A manual is located at http://www.scribd.com/doc/29550374/Amana-HTM-Plus-Manual
Dec 03, 2008 | Water Heaters
Delta & Single Handle Shower Faucet  Logo
93 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
