Why do I get buzzing each time I increase the volume on my hi -fi?
  • joeloss
    joeloss Feb 11, 2012
    Whenever I increase the volume on my Technics SU-X950 integrated amp, the sound of the record is cancelled out by a loud buzzing. This only seems to happen when I use the turntable.
  • 23 Answers
What type of set up do you have ....an old zenith that was a turn table,radio in a cabinet or independent units, such as separate receiver, tape/CD /DVD Playing Recording unit? Also check connections in back of speakers (if they are separate from unit. It can be a number of things from bad Volume pot to a "magnetic' device to close to speaker system,to a bare connection to accidentally shorting against another connection. Check all your connections first. Hope this helps, Best Regards,Steve
Posted on Feb 11, 2012
I8ncrease volume of lgp500
If you mean speaker volumer during In call .. Go to settings>Sound here you can adjust the volume for Incoming calls and simple Volume.
May 24, 2014 | LG P500 Optimus One With Android Os Wi-fi...
My sony hi-fi lbt-sh2000 component sound volume does not increase after long hours playing
example you play music high base and thin you give a high volume.have a automatic sensor inside the player to low the high base.
Feb 06, 2013 | Sony Main Body Of Lbt-Sh2000
Working fine for the last 20 years with my arcam delta 290 then whilst on my ps3 the av processor started to make a buzzing tone through all speakers. tried all the different modes, unplugged, checked...
In nearly all cases buzzing on audio equipment is caused by faulty leads or having leads in close proximity to EMF sources. Remove all the input and output leads, does the it still buzz. Connect the speaker leads, does it still buzz? Then connect the input leads one at a time. This should pinpoint where the problem is. If you find a faulty lead, swap it out for another, new quality lead that is shielded. Others have the same problem :>(
arcam delta 290 buzzing Google Search
Jun 18, 2017 | Kenwood Audio Players & Recorders
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
Mar 08, 2008 | Vizio L37 Television
Loud buzzing noise
oil the blade with clipper oil, a couple of drops on the teeth
Oct 28, 2007 | Oster 76974-160 Hair Trimmer
VCR Hitachi F361
The noise from the TV is called 60 cycle hum and it is caused by a capacitor that is open, a test for ripple voltage will confirm this The noise from the VCR is more then likely common mode noise which would not be heard but for the bad capacitors in the TV. Simply put the common mode noise is being added to the 60 cycle hum. Now for how to fix this, if you have a background in electronics you can use a schematic, multimeter and an oscilloscope and Multimeter to find the bad capacitors, and the schematic to tell you what the voltages and %ripple should be. If you do not have a background in electronics, take the set to be repaired
Sep 29, 2007 | Hitachi VTFX631A VCR
Hitachi VCR F361
You need to change the Audio / Control Head, as well as the Pinch Roller of the machine. A worn out Audio cum Control Head will reflect in poor tracking and so will cause the above problems.
Buzzing speakers
It is merely degradation of the connection. Try unconnecting the speakers, cleaning the tips a bit, replacing them in, removing, recleaning, and then replacing a final time. This should get some scoring off of the connection... Aside from this, a new set of speaker wire is the best solution but just let me know what you decide on! Hope this helps!
Jul 26, 2007 | Sony MHC-ZX70DVD System
 Grubhead
Grubhead
