Question about Tools & Hardware - Others
0603272139 3272A Bosch - Planer Manual - Tools & Hardware - Others
How do I download dewalt 733 manual?
Try Googling (DeWalt)(733)(manual) without parens.
Apr 27, 2017 | Dewalt Drills
Need a manual for Craftsman Contractor series 12 1/2 Planer #351.23383
Go to the Sears Parts Direct web site and search for the Planer model number. I got two results, the second one had a link for the manual. Here is a direct link: 351233831 CRAFTSMAN 12 1 2 PLANER MOLDER Manual
Jul 06, 2014 | Craftsman 12 amp 12-1/2" Bench Planer...
The roller for the planer blade is stuck
Turn Off the device.
>> Remove the blade and set for correct hight and place.
Mar 29, 2014 | Bosch 3365 5amp Planer
Tips for using a planer
keep your fingers out of the way . if you don't know how to use = you shouldn't be using .
Dec 16, 2012 | Bosch 3365 5amp Planer
My Bosch 18V planer 53518 just stopped working. Worked fine one day, picked it up the next day, nothing!! Batteries fine, checked belts, etc. I see no problem. Any suggestions?
Did you ever figure this out? Mine just did the same thing. Fresh battery. Pulled trigger. Started to run, then just stopped. Don't know if it's the switch, motor or something else.
Oct 28, 2011 | Bosch 18V Cordless Planer 53518
How do I change the blade on a 3365 planer
Page 7 of this manual describes how to replace blades:
https://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D//t10/0000000/r00143v-1.pdf
Feb 21, 2011 | Bosch 3365 5amp Planer
I cannot get my Bosch 1594 planer to go to actual zero on cut depth.It always removes some material even when I have it dialed to zero.I have had it for a number of years and it has never been able to do a...
The unit will most likley have to be dismantled and the depth adjustment system checked for proper operation. Sometimes a bit of wood shavings will get lodged in the screw mechanism and keep it from traveling to its full range. This will most likley cause a sitiuation where you won't get actual zero. Bosch has online drawings of all their tools if you want to perform the service yourself or you can go to a service center to have it checked.
Dec 19, 2009 | Bosch 1594K 3 1/4" X 3/32" Planer Kit with...
How to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Sep 16, 2009 | Bosch Tools & Hardware - Others
Tools & Hardware - Others Logo
283 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
