Question about Nikon COOLPIX L21 Digital Camera
Nikon Coolpix L21 not switching on.
The camera doesn't switch on. When pressing the power button, only the power light (green) turns on, I hear a click sound and that's it. The lens doesn't come out. The display remains blank. I've used the camera for a long time and warranty period is over as well. Please suggest a solution.
  • divyasharan0
    divyasharan0 Feb 11, 2012
    Additional Details - I put 2 new batteries in it a week ago. So, it shouldn't be an issue with dead batteries anymore.
  • divyasharan0
    divyasharan0 Feb 12, 2012
    Thanks for the reply guys.... Took it to the service center (as all other methods failed after repeated tries). They are charging more than half of the Cam's MRP. Guess, I'll have to buy a new one instead. :(
Rammsteins
  • 300 Answers
SOURCE: my 9 month old camera (Nikon s210 coolpix 8.0mp) that I
Hi!
It sounds like the lens focus is stuck. If you don't have experience in camera repairs, you should give it for a repair to your local Nikon service center or other camera service center.
Tom
Posted on Jul 31, 2009
  • 102366 Answers
SOURCE: hi i have lens error with my nikon coolpix
Sadly, the camera needs service.
Posted on Dec 29, 2009
  • 540 Answers
SOURCE: Nikon P60-Screen is blank and lens doesn't retract.
Please remove the battery for few hrs and charge them after that replace the battery and try to power on if the problem persist then take to any service center the firmware needs to be updated or there is some short in the circuit board of the cam.
Posted on Feb 16, 2010
rajdeepdutta
  • 2517 Answers
SOURCE: cost for camera repair-nikon coolpix s220
Depend on the country. approx cost 20$ - 40$. Thanks.
Posted on Mar 14, 2010
  • 1170 Answers
SOURCE: nikon coolpix s630, lens error, blurry, ticking sound
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 31, 2010
Why doesn't the switch on my Nikon Coolpix 2100 work
Make sure you are holding the power button in for 2-3 seconds. just pressing it for a short time will not turn it on!
Feb 04, 2018 | Nikon Cameras
Coolpix P80 camera doesn't turn on when I plug in the data cable?
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
Mar 28, 2013 | Nikon COOLPIX P80 Digital Camera
My nikon coolpix says card cannot be read
Try switching the button back and forth located on one side of the card several times to unlock the the sd card, sometimes switch contacts become dirty.
Aug 19, 2012 | Nikon COOLPIX S1100pj Digital Camera
Nikon Coolpix L21 exhausted baterry
Are you using the correct type of battery? Those cheap disposable carbon batteries simply cannot power cameras. you need at least alkalines. even better- lithiums or Ni-MHs.
Apr 16, 2012 | Nikon COOLPIX L21 Digital Camera
I use some new alkaline batteries but the camera (Nikon 5600 coolpix) doesn't go on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 11, 2011 | Nikon Coolpix 5600 Digital Camera
When i plug my nikon coolpix into my computer, my computer doesn't think it's plugged in and nothing pops up for me to transfer photos.
Hi there, To get your camera to connect to your computer, follow these steps: 1) Enable USB mode - press menu, go up, and select setup. Select USB and press OK. Select Mass storage and press OK. Save the changes. 2) Make sure the PictureProject software is installed from the CD that came with the camera. 3) Launch PictureProject 4) Connect the camera to the computer 5) Turn on the camera and press the "transfer" button. Alex
Jun 04, 2011 | Nikon Coolpix S4000 Digital Camera
My Nikon Coolpix S220 camera getting problem. Upon the power switch press to ON the power-on lamp (green lamp)blink for few minutes but the LCD monitor never turn ON. After the green lamp OFF then the...
I cant detect my pics in my laptop from the sd cars. But I can see in my camera when I insert the same sd card. Is there any problem with sd card or any virus effected? How to upgrade the sd card. please help me out.
Feb 01, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
I cannot activate Nikon Coolpix S210 (problem with ON/OFF button)
had a similar issue with my Pentax, it would power on and power back off. Tried playing with it for a while and it never recovered. Chances are its time to replace it. These new electronics are jam packed with lots of mini moving parts and are prone to excessive wear over time. they're are no servicable parts inside them unfortunately. I would try ebay for a reasonable replacement camera.
Aug 06, 2009 | Nikon Coolpix S210 Digital Camera
Nikon COOLPIX L21 Digital Camera Logo
279 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
