Question about Frigidaire ATF6000ES Front Load Washer
E20 My washer don't seem to be finnishing its cycle. I dont think it is spining. it will start beeping and has E20 flashing on the pannel.
The door won't lock, then i broke the grey thing that the door prong or latch locks into by slaming the door. its a little plastic grey hole hole. i don't see what holds the grey plastic thing in the hole. or how to order it. can you help. ? but the door wouldn't lock before that, i think the 3 and 4 year old kids play hanging on the door. how do you fix it. 2006 afinity fron loader washer. thank you. cheryl
Posted on Oct 25, 2008
Tumble action washer keeps giveing me E20
first, find a manual or contact tech support to determine what an e20 means. it could be a clogged drain.
Jun 02, 2014 | frigidaire.com
My kenmore he washer will not drain all the water also have code E20 flashing
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Kenmore HE2 Plus Front Load Washer
I have Kenmore front load washer(don't have the model # yet)...during the normal wash cycle..at the end of it it does not spin, the diplay show E20. What seems like the problem??
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Zanussi Electrolux ZWF 1430 W and it's coming up with an E20 error code. The machine starts off OK but after about 25 minutes the Error Code E20 starts flashing in display and the machine stops...
E20 is a draining error.
  1. First, try to reset the machine to factory settings first by setting cycle selector to off position for 5 sec, then to spin for 5 sec, then back to off for 5 sec, and then to spin. The machine should reset allowing you to select the drain cycle and get the water out of the machine then run a spin cycle to clear any remaining water before you unscrew the filter to clear it.
  2. Next, you need to take the filter out at the front, bottom right, of the machine, empty it of all lint and replace it. It may have water trapped in so be ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out.
  3. If this doesn't fix the problem, check your drain pipe hoses to make sure they are not kinked and flush them out.
  4. Last but not least, replace the drain pump.
Jan 08, 2010 | Zanussi ZWF1430W Front Load Washer
E20 flashing mid cycle
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jul 01, 2009 | Zanussi ZWF1430W Front Load Washer
E20 code. Not draining
Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
95 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
