Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Belt change to GE dryer spacemaker type MD2A
Ser # SM531921A
3 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Posted on Dec 25, 2008
  • 8 Answers
SOURCE: GE spacemaker dryer won't start
Have you tried keepin the dryer door open, depressing the safety switch which enables the dryer to work when it is closed, and then turn on the dryer to see if it turns at all? Sometimes its the smallest things that cause these problems. That switch that gets pressed when the door closes, sometimes malfunctions. Sometimes the door of the dryer gets out of whack and doesnt really make contact with the switch enough to trigger the flow of electricity.
Posted on Jan 13, 2009
How to install a heating element in the GE wall mount dryer
GE Dryer design (Most or almost)....
Heating element access is from the front.
1. Remove the Front Door
2. Remove the belt.
3. Remove the Drum.
You see the heating element. Very simple design
Apr 06, 2015 | GE Dryers
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Jan 30, 2013 | GE Spacemaker Washer and Dryer Electric...
Install dryer belt any tricks to make it simple on a GE WSM2700W/WW/AA Top Load Stacked Washer / Dryer
Nothing on a stackable is easy to replace and no tricks so just take your time and you'll get it on.
Sep 27, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
The belt in my dryer is squeeking. What type of
It's probably the front tub guides that are worn out causing the squeak. It's a felt lined circular shaped guide that holds the front of the tub. The rear of the tub is held by a ball and socket bearing. Access to the guides is behind the front panel of the dryer. Remove the screws across the top
May 10, 2010 | GE Spacemaker Washer and Dryer Electric...
My Dryer portion of my GE stacked washer/Dryer will turn on and I can hear the motor running but the drum will not turn. I pretty sure is the belt. I haven't been able to locate a schematic anywhere of the...
Not that easy but go to this web site www.applinace pros.com and look at it's diagram and you can see if you want to tackle this issue, if you do and rn into problems you can get help from us here if you need it.
Nov 13, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Jan 01, 2009 | GE Spacemaker Washer and Dryer Electric...
Ge spacemaker washer and dry stackable.
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
88 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
