Question about Kyocera Office Equipment & Supplies
What is code error c0640 on kyocera km-2560 - Kyocera Office Equipment & Supplies
  • 523 Answers
Corrupted data. clear the all the jobs from the que. restart the machine and this will fix. if not means bad hard drive.
Posted on Jul 23, 2017
  • 43 Answers
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Posted on Mar 02, 2008
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
  • 38 Answers
SOURCE: Error Code 2102
this is either a problem with your network cable connecting the machine to your network, or the network point, or the network switch.
Another possibility is that the SMTP (E-mail server) IP Address has changed or has been entered incorrectly. This is the most probable cause, especially if you can print to the device without any problems
Posted on Oct 26, 2008
  • 126 Answers
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Posted on Mar 02, 2009
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Posted on May 26, 2009
Iam able to do a system print out but cannot do a copy
if you can not scan a copy from doc feed or glass may have a bad hard drive. will pull a error code C0640
Jun 21, 2014 | Kyocera Mita KM-3035 All-In-One Laser...
Hard disk drive problem
The hard disk cannot be accessed
the main PWB and the connector on the
hard disk. Repair or replace if necessary.
Defective hard
Run U024 (HDD formatting) without turning
the power off to initialize the hard disk.
Replace the hard disk drive and check for
correct operation if the problem is still
detected after initialization.
Defective main
Replace the main PWB and check for correct
Apr 17, 2014 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Km error code cfb31
firmware update is the only solution sorry about that but you can contact me if you really need the firmware +2560702155632
Dec 10, 2013 | Kyocera Copystar CS-2560 Black and White...
Kyocera km-2560 c6400 zero cross signal error
To reset this error hit 10871087 this will put the unit in Maint. Mode. Then press 906 then press start.Execute will appear on the screen press it. Either the machine will turn off by itself or it will say on the screen to turn the unit off then on using the power switch on the side of the unit. If the code comes back after all this either the fixing unit or the power supply are bad.
Hope this helps.
Jun 27, 2011 | Kyocera Copystar CS-2560 Black and White...
Error c6000 kyocera km-2560
Feb 15, 2011 | Kyocera Copystar CS-2560 Black and White...
I have Kyocera km-2050 it coming error for call for services error code -C6400
press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Dec 05, 2010 | Kyocera CS-2550 Black and White Copier
Hi We're using Kyocera Mita KM-2560. Unfortunately someone in our office was able to change login settings through device internal web interface. When I turn on the machine it asks username and password....
try Admin on both username and password ( A caps).
Also try 3000 on both or 6000 on both. try to select the system menu button and type the username and password there.
Jul 20, 2017 | Kyocera Office Equipment & Supplies
1,794 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
