Question about Akai DVDRW120 DVD Recorder
Akai DVD recorder tray will not open
My Akai DVDRW120 DVD+RW recorder modified with code free PAL/NTSC playback that was manufactured in Feb. 2004 does not open its tray when the eject button is pushed on the recorder or remote control. What can I do to fix this? I dont want to send the unit back to Akai for repair. Thanks.
  • 1 more comment
  • Anonymous Jan 07, 2008
    DVD/CD player will not open tray. Disc is in there.
  • akaidvd Apr 05, 2008
    tray opens and closes repeatedly there's no way to stop it unless power is off
    does anyone knows what could be the problem?
    thx
    luissimo
  • adcraig Jun 21, 2008
    Hi, I have the same problem, the tray will not open manually or with the remote control. Please Help.
    Alan
    adcraig@bellsouth.net
I am pursuing the exact problem above. I have found a not so hi tech solution. I firmly rap on the top above the disc drawer. This is while Close is being displayed and the drawer is in. If you hear some spinning and load displays it should now work. It may be back to cycling again on the next ejection though.
Technically I figure it may be a sticky magnetic reed switch or what ever they use to detect the drawer position. Mine displays either open or close when it starts to cycle.
Posted on Dec 18, 2009
    New Friend:
  • 163 Answers
When you push the open buttom its try to open? or do nothing, any way remove the cover, and give a little push to the tray, when press the open button, listen to motor noisese, are tere? if yes, have a broke driver part, if nothing happen then you need a tech, have a damage driver circuit...good luck
Posted on Aug 09, 2006
SOURCE:
I have a Koss KS4190 DVD player with unreadable menu screen.
follow this steps and fix it. Merry Christmas.
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Dec 17, 2013 | Samsung DVD-VR375 DVD Recorder/VCR
Region codes
dvd players are suitable for all regions but the pins may vary region to region
May 13, 2008 | Sharp DV-NC200
I have an AKAI DVD RECORDER DVDRW 120... 3565-1546/ My problem is that the tray is stuck and will not open. I do not want to pry it open and am hoping that you have a solution that can help me.I have...
This is a common problem. There might be a cd stuck inside (they ussually get stuck on top spindle) plug out and open cover and manually release cd
May 12, 2011 | Akai DVDRW120 DVD Recorder
Which DVDs do I need to use with the Toshiba DVR19DTKB2 I have DVD+R Will these record from VHS
Compatibility Recording - DVD-R, DVD-RW, DVD+R, DVD=RW, VHS
Compatibility Playback - CD-Audio, CD-DA, CD-R, CD-RW, SVCD, Video CD, DivX version 6, DVD-R, DVD-RAM, DVD-RW, DVD Video, DVD+R, DVD+RW, JPEG Viewer, MP3, NTSC Playback (VHS), USB 2.0
Mar 07, 2011 | Televison & Video
Which DVD file play in this player
Disc playback capacity for the LG DN788 is as follows:-
Audio CD
CD-R
CD-RW
DVD(NTSC/PAL)
DVD-R
DVD-RW
DVD+R
DVD+RW
Dual Disc(DVD+CD)
May 27, 2010 | LG DN788
What is the Toshiba RD-XS34 region-free code? I live in Australia, and would like to play a dvd I have brought from America..
DVD player region-free codes.The DVD player can play both NTSC,and PAL.Play all NTSC DVD this format is in US,Canada,Mexico.PAL DVD format is in Europes,Asia,and Middle East.
Mar 21, 2010 | Toshiba RD-XS34 DVD Player/HDD Recorder
Dvd keeps reading no disc
It can be several reasons
1. Disk is upside down
2. Lens is durty. You will need to use CD/DVD cleaning disk for that
3. Disk is having diffrent region code or recorded in diffrent formate (for instance player playback disk recorded in NTSC, and you trying to playback disk in PAL formate)
4.Disk is recorded at higher speed (for instanse player markered X16, but disk is recorded at X24)
Good Luck
Dec 24, 2008 | Televison & Video
Video bought in carribean
If you got the video recorder in another country you need to check to see what it uses to scan NTSC or PAL because Kuwait is a Country taht uses PAL and if you have a vcr that uses NTSC it will not play those cassettes. Let me know where you got your camcorder from if its not on this list maybe i can find out for sure if it is NTSC or PAL. Here is a list of some countrys that use NTSC and PAL
www.terrascope.org/NTSCvsPAL.html
Jan 02, 2008 | Microsoft Xbox 360 Console
Manual lost
akai phone # use to be 310-664-8060
Apr 28, 2007 | Akai DVDRW120 DVD Recorder
DVDRW120
I have no remote control akai dvdrw120, someone I could provide a model to be able to locate.
Dec 27, 2006 | Akai DVDRW120 DVD Recorder
Akai DVDRW120 DVD Recorder Logo
372 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
