Question about Refrigerators
How do I charge the R134a in a beverage-air model UR30GFD
2 Suggested Answers
  • 1253 Answers
SOURCE: Beverage Air model DP93 tag states 9.5 ounces of
It's been my experience that in most cases, it is very difficult to get the exact amount in that is on the tag. A 5 ft. hose can hold up to 3 oz. of liquid and on small systems, it will drive you nuts. Always go with what you know. Charge the unit to proper pressures and watch it for a while to see if it is doing what you want. The charge may have to be 'Tweeked" to get it right.
Posted on Nov 28, 2010
I have water accumulating in the refrigerator compartment. How do I access the condenser area to figure out what is wrong.
http://beverage-air.com/uploadedFiles/docs/SPE60%20Cutting%20Top.pdf
REFRIGERATION
More robust refrigeration system
provides added capacity and efficien-cy. Systems are designed using CFC free R134a refrigerant. Forced
air from evaporator is moved under pans, which are recessed 2" from
top of cabinet. Forced air over the condenser is drawn from back and
bottom of cabinet. Automatic condensate evaporator is provided to
eliminate the need of floor drains.
Automatic condensate evaporator malfunction.
Jun 13, 2015 | Beverage-Air SPE60
R134a recharge instructions
There are no instructions. Valves need to be brazed onto service pigtails after market. The usual techniques of line taps, reclaim, braze permanent Schrader gauge port valves, evacuate, and critical charge is used. Not the good old days any more.
Jan 28, 2014 | Beverage-Air Refrigerators
My haier beer dispenser model HBF05EBSS will not turn on. Compressor is hot and keeps clicking on and off. How can I fix
Try to change the capacitor and start relay first...then maybe if that don't work the compressor...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 31, 2010 | Haier (HBF05EAVS) Beverage Dispenser
Beverage Air model DP93 tag states 9.5 ounces of R134A however seems undercharged when this amount is weighed in and immediately becomes effective with a few more ounces. Could the tag be wrong???
Jul 14, 2010 | Beverage-Air DP93 Refrigerator
Head pressure high; suction pressure low. Unit not cooling
Good day,
It's a restriction.
It could be in the liquid line dryer, cap tube as well as the condenser. If it's a R134A system, it's a common problem.
In either case, the repairs can become extensive, with the factory when under warranty, authorizing, replacing the dryer, cap tube,
condenser, and many times the compressor.
Feb 03, 2010 | Beverage-Air DW64 Beverage Cooler...
Beverage air model sur27 refrigerator r134a powers on but doesn't get cold. compressor doesn't get cold not sure maybe it's the relay........if and when the ploblem is solved, is it hard to get parts for...
The larger pipe on compressor should get cold. The smaller should get warm to very hot depending on ambient conditions. Parts should be available, including a universal relay kit I could hook you up with. First determine if the compressor is running. Let me know. :)
Sep 19, 2009 | Freezers
Need to know what type of freon to use to recharge a one yaer old Beverage Air Sandwich table refrigeration unit. Is this the same process as recharging an automotive AC system?
Beverage air used R134a almost exclusively on refrigerators. The process is similiar to ac systems. You should weigh the charge in as per the data plate. Be precise as over or under charge can dramitically affect the performance of the unit. Hope this helps
Mar 29, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Beverage air dd78e not cooling
change setting on thermostat and see if anything changes. If yes, that's the prob if no, freon level. start there.
Dec 14, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Won't get cold?
in the sealed system you will need to tap it
May 04, 2008 | Beverage-Air BEVBM23 Commercial Beverage...
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
