Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Picture going out
LINES GOING THROUGH THE SCREEN
Sounds like theres a problem with the tube inside the television. most of the time they arent worth fixing as its costly.
Posted on Feb 11, 2012
Why does my sanyo flat screen TV have vertical coloced lines on screen with no picture?
Check the ribbons going in between the boards and "work" them to clean up all connections. And on the main board look for possible bad caps.
Your t con board is responsible for all picture distortions but not the vertical lines you described.
Feb 25, 2016 | Sanyo Televison & Video
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
The TV will work for a while and then the picture will get lines in it and then the tv will shut itself off.
This Is IK shutdown, this may be from a bad picture tube going bad, or excessive high voltage, If the screen turns a certain color right before shut down then thats the tube going bad, It will either be RED/GRN/BLU screen right before shutdown, the lines are scan lines. If a tube needs replacing then it might be hard to get as CRT manufactures are not making many any more. You can contact http://www.VDC.com for used or remanufactured one.
Dec 09, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Picture has lines going across
No picture tube is cheap to replace. Especially a Sony tube. And besides the cost of the tube there's the labor cost to install it and some tedious adjusting needs to be done to set up the replacement. When a picture tube fails it's time to replace the set.
Now having said all that, there are different kinds of lines that can show on the screen. Some are because the tube is bad, but others can come from less expensive parts on the circuit board in the set. Without seeing the lines for myself I can't tell you about yours. If you are wanting to keep the set, I would suggest having a qualified shop check it. The can tell you for sure if it's the tube or not, and give you an estimate for the cost of repair.
Apr 18, 2009 | Zenith C27A24T 27" TV
GREEN VERTICAL LINES
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
Lines in picture
can you post a picture of the lines that are going across your screen? Sounds like maybe retrace lines.
Feb 14, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
No picture
these systems usually go alomg with a power supply going bad the last one i did tthe 24 v converter for the picture went out.
Aug 14, 2007 | Polaroid FLM-3734B 37 in. LCD HDTV
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
