Question about liftmaster Home Security
2245 C liftmaster
The light on the lift master doesn't turn on when I open the garage.
  • 8 Answers
SOURCE: LIftmaster light flickers but won't open garage door
check your wire connections at the opener one of the little wires probably broke
Posted on Jan 10, 2009
  • 5 Answers
SOURCE: Liftmaster Garage Door Opener Problems...
The problem lies in the RPM sensor, most likely due to the interrupter cup assembly. The interrupter cup assembly is the black cap that runs through the RPM sensor. You may have forgotten to re-attach this piece or it is probably moving too far out when the garage sets in motion. To fix this, remove the cup assembly, unscrew the two screws on the top metal piece with a 1/8 allen wrench, push the metal piece as far in as possible and put the screws back on. This will give more room for the cup assembly to spin and be read by the RPM sensor. Hope this helps!
Posted on Jul 10, 2008
SOURCE: I can not hook up Honda odissy 2007 Homelink system with LiftMast
Yes. But you need a remote transmitter that is programmed to open the Lift Master. Then you just follow the instructions in your home link and it should work.
Press the homelink outside 2 button at the same time and hold till fast blinking (all erased). Then press homelink button1 and hold while aiming the transmitter (2 inches away) and pressing appropriate button on the remote. Continue to hold both till fast flashing seed on the homelink. Release both. Then hold the next button on the homelink you want to program, aiming the remote again, and pressing and holding the appropriate button on the remote, until fast flashing, and then releasing again, ......
Posted on Feb 06, 2009
  • 3197 Answers
SOURCE: Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Posted on Apr 05, 2010
  • 3197 Answers
SOURCE: My lift master security plus keyless entry pad for...
You can try programming it but first make sure the battery is good. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
Posted on May 24, 2010
I need a remote keypad for 41a5021-1e lift master. What model will work for this unit
check the liftmaster web-site. also any garage door sites may have parts offerings. google the part number as well.
Nov 05, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Lift master 91LM
Won't work doesn't give us much to go on. Does it work with the wall control?
Jun 28, 2012 | Sears Craftsman LiftMaster Chamberlain...
Push buttons on remotes won't raise/close lift master mod 81lm
Check to see if the light in the wall control is flashing. If it is press and hold the lock button for 3 seconds.
Jun 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
I need a new remote for lift master garage door opener with part number 41A3627 and cert # K710 FCC ID HBW1D3605
Those numbers won't help. The model number is on the opposite end of the opener from where you found those.
Oct 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: I need a remote for a Lift Master Professional ...
The model number will be on the opposite end of where you found the part number you listed. You can then call any Liftmaster dealer listed in your yellow pages.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Vacation mode keeps coming on our craftsman lift master garage
You possibly have a bad wall control. You say it comes on as soon as the light goes out. What light are you referring to?
Jul 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
57 people viewed this question
Top liftmaster Home Security Experts
Lawrence Oravetz
Are you a liftmaster Home Security Expert? Answer questions, earn points and help others
