Question about Garden
Fuel line routing on Stihl 029 Super - Garden
  • 211 Answers
SOURCE: Fuel line for Stihl 025 chainsaw
Hi
It happens sometimes.You have to replace the fuel line.This is a trick.Remove the gas tank cap and take off the fuel line and remove the fuel filter.Take off the fuel line from the gas tank.Cut off the piece of the fuel line wich is larger and seals the gas tank.Now through that piece of fuel put an ordinary fuel but about the same diameter.Put all back and that is all you have to do.If you need farther info just let me know. best regards savumihai71
Posted on Dec 20, 2008
crapiemael
  • 241 Answers
SOURCE: Need to know where the FUEL FILTER is on the Stihl 029 model
Some chain saws have the filter as the little bulb that picks up the gas down in the gas tank. Remove the gas cap and look in the gas tank. Using a piece of wire with a small hook bent into one end, reach into the tank and catch the pickup bulb. Slowly pull it out of the tank. Clean it with clean gasoline.
Posted on Jun 05, 2009
dontbother10
  • 2220 Answers
SOURCE: Replacing the fuel vent hose on a Stihl chain saw
I'd try to contact them. Stihl IPLs are proprietary (not on-line) they may be willing to provide you one. it will probably have the detail needed to answer your question.
Stihl USA
http://www.stihlusa.com/contact.php
HTH
Lou
Do you have more than one Stihl dealer close? Sounds like this one doesn't need your business!!!
If all else fails someone with your model saw will probably help you here: Please do a dearch your question may have been asked and answered.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Posted on Nov 19, 2009
  • 4088 Answers
SOURCE: Got a Stihl 029 super, fresh gas ,vapor coming
Fuel may be leaking past the carburetor fuel flow needle and seat due to dirt negating the control action of those two components. A tear-down and cleaning of the carburetor would likely help. Check the condition of the diaphragms and valves as well. There is a complete description of 2-stroke carburetor action (Walbro brand) at:
http://www.drystacked.com. It's a 12 page PDF. Hope this helps!
Posted on Dec 31, 2009
  • 67 Answers
SOURCE: stihl 029 super oiler is not working
Pull off the clip and sprocket, then check the spring or wire behind the clutch. There is a notch in the sprocket hub that drives the spring when the hub is spinning. Sometimes the spring comes off the worm gear that it drives. If the spring is not there you need to remove the clutch to check it. It has left handed threads on it)
Posted on Apr 08, 2010
I have an stihl 029 super chain saw that the spark plug won't stay in it. What parts do I need to fix it?
If the threads are crossed, stripped or loose, you need to take it to an engineering place and have a 'helicoil insert' fitted, this is a new steel insert that is tapped and threaded into the head after the hole has been enlarged a little.
helicoil insert Google Search
Dec 12, 2016 | Stihl Garden
Engin parts for 029 super stihl chain saw
perhaps a STIHL dealer can assist you .
Dec 09, 2016 | Cars & Trucks
How remove fuel tank from a stihl 029 wood boss ?
stihl have a range of pdf version workshop manuals for their equipment
go google and enter details and download the manual for your machine
Jun 18, 2016 | Stihl Garden
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Stihl 029 super oiler is not working
Mar 08, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Got a Stihl 029 super, fresh gas ,vapor coming from carb. wont idle,help
Dec 31, 2009 | Garden
If it's the clear vent hose that connects to the tank on the left side, that's it. There is a brass plug inside the hose that meters outside air in the tank to regulate the pressure. The hose connects to the tank nipple, done.
Nov 19, 2009 | Garden
Garden Logo
429 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
