Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Fridgidaire Gallery Series Side by Side Refridgerator
I purchased my fridge back in Dec 2004 and recently we noticed a pool of water underneath the freezer part. We mopped it up thinking it was probably just ice that fell from the ice despensor. Well the pool of water continued over timeand we realized the fridge was actually leaking. We moved the fridge out, checked the connections etc, everything was fine. Plus no water back of fridge near connections.
We called repair, he checked things and assured us it was just the connections. Well the fridge still leaked. Repair called again, we even unhooked the connections. We felt no water to fridge no leak. It continued to leak, for 3 weeks after we unhooked the water from fridge.
The repairman has no idea what it could be other then telling us that he should replace all parts to correct the problem.
Looking for a simple answer.
  • jennycub Oct 26, 2008
    I have the exact same problem and would love to find a solution. We've also had repair out to look at it, can find nothing wrong. We've checked all connections, nothing disconnected or out of place. Water freezes in the bottom of the freezer, so the bottom pull-out shelf is not usable because everything will eventually freeze to the bottom.
  • gardenof5 Nov 03, 2008
    We have had the same problem as well but intermittently. However, I did "catch" it in the act while a small trickle of water was running out of the ice/water dispenser. My theory is a thermostat issue that is causing the freezer to get stuck in the defrost mode? Often times, when this happens, the ice is rather "melty" and then after a few days, we stop getting ice and notice that the ice maker is jammed and the cubes are halfway melted and appear to have refrozen on the tines of the ice maker causing it to seize up. We were tired of the problem and just bought a GE and are selling the Frigidaire with full disclosure of the ice maker problem. I figure by the time we pay for a repair (parts & labor), we'll break even with selling the old at a bargain price and buying a new one.
    President:
  • Frigidaire Master
  • 2,651 Answers
"jennycub" sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine. very common problem( easy to detect. water on the floor of freezer compartment) as far as the other posting by" humblerumble", ive seen where the drain tube under the refig has pushed a hole into the drain pan under the refrig, in which case it will only leak after a defrost cycle, with the kickplate removed grab a flashlight and look under the unit for the drain pan as you pur water into the back of the freezer sect to trace water flow
Posted on Oct 29, 2008
Water leaking outside of fridge
Do you notice if the water was coming from the dispenser door area or from underneath the unit? Did this unit recently go into a defrost cycle at all that you might know of?
Aug 22, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water leaking from the water filter inside top right of fridge when getting water on side by side fridgidaire gallery series. How do I correct?
If the filter itself is leaking then you will need to replace the filter, otherwise check the o-rings and lines going to the filter.
Sep 25, 2011 | Frigidaire GLHS38EES Stainless Steel Side...
Just purchased a fridgidare Gallery Series counter depth side by side fridge. was delivered today - water line hooked up. as soon as we turned on the water and pressed the dispenser water was pouring out...
Check water line just below the freezer door. This is where there is an water-line hook up that may not be connected.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - We repair refrigerators and all other appliances in the Houston, Katy, Spring and Woodlands, TX areas!
Aug 29, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a fridgidaire refrige and water keeps pooling in the bottom of the refrige and then leaking out the bottom when it fills.....what is the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Hi, i noticed water coming from the back of my fridgidaire fridge model ftr81sgh
sounds like a frozen water inlet to ice maker . needs too be defrosted and may need a water valve as it may not be shutting of completly .mm
Aug 10, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
Bottom of fridge collects water
Hello there:
I have written a few steps for you to follow and try ok?
  1. Manufacturers have different ways to dispose of the water created during automatic defrost cycles. The most common design routes the water down a rubber tube on the back of the fridge to a tray beneath. This tube often gets plugged with breadcrumbs, peas etc. and can generally easily be removed and cleaned.
  2. Make sure the end of the hose is sitting in the defrost tray.
  3. If your hose was not plugged and you have found water running down the back wall inside the fridge or a pool under the bottom crisper has formed. Check if there is a small funnel located on the back wall near the top inside the fridge. It can also get plugged; you can use a small wire and work it in and out of the hole.
  4. Some designs do run the water down the back wall and have a drain hole under the crisper, make sure it is not plugged.
I hope that this has been verry helpfull for you
best regards michael
Nov 06, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water on floor under side by side gallery refrigerator
Hi there check wether or not the boil away tray underneath the fridge has an element if it does check to see if it is open circuit ,if so replace element.Hope that helps.
Dec 17, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
300 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
