The red light indicating cartridge replacement was blinking.I replaced the cartridge with a new cartridge from Staples # E 20. Following the instructions installing the unit the trouble light keeps on blinking. What could be the cause ? What did I do wrong.? Thanks.
SOURCE: Alarm light
hmmm..unhook printer from pc...restart and run a menu test page...
if that works, re connect to the pc..
and you might need new drivers get em here
SOURCE: Printer won't print on my MacBook
Mine won't print from PC. checked everythong, re-installed drivers, got new ones... nothing, ...yes even formated the pc. but nothing.. unless i connect it to my canon s5 cam.... then the &"¤?& thing works....
SOURCE: Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
SOURCE: Adding Staples Image Runner 330S
depednding on sorter im guessing its the small sorter with one tray the stapler is in the rear of the sorter green handle pull it out uses L 1 staples
SOURCE: reset ink counter for canon mp630
The cartridges have small chips on the lower face Once it registers empty that casette will not woek again. Many of the replacement cartridges that are not genuine have this chip missing. You can transfer the old chip to the new vcartroidge ( if its not a genuine with a replacement reset chip. I think you can by a chip resetter for this model. do a web search fot your model they are por etty cheap to buy
That"s all I did. The unit from Staples is compareable I was told.
