Question about Garden
Fuel hose routing on a Stihl 029 Super - Garden
  • Kenneth W. Wright Feb 13, 2012
    There is a hose on this saw that comes off the top of the tank but I can't see anywhere for it to connect . Without it gas spews out the connection or runs out when you tilt the saw
dontbother10
  • 2220 Answers
SOURCE: Replacing the fuel vent hose on a Stihl chain saw
I'd try to contact them. Stihl IPLs are proprietary (not on-line) they may be willing to provide you one. it will probably have the detail needed to answer your question.
Stihl USA
http://www.stihlusa.com/contact.php
HTH
Lou
Do you have more than one Stihl dealer close? Sounds like this one doesn't need your business!!!
If all else fails someone with your model saw will probably help you here: Please do a dearch your question may have been asked and answered.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Posted on Nov 19, 2009
  • 4088 Answers
SOURCE: Got a Stihl 029 super, fresh gas ,vapor coming
Fuel may be leaking past the carburetor fuel flow needle and seat due to dirt negating the control action of those two components. A tear-down and cleaning of the carburetor would likely help. Check the condition of the diaphragms and valves as well. There is a complete description of 2-stroke carburetor action (Walbro brand) at:
http://www.drystacked.com. It's a 12 page PDF. Hope this helps!
Posted on Dec 31, 2009
  • 67 Answers
SOURCE: stihl 029 super oiler is not working
Pull off the clip and sprocket, then check the spring or wire behind the clutch. There is a notch in the sprocket hub that drives the spring when the hub is spinning. Sometimes the spring comes off the worm gear that it drives. If the spring is not there you need to remove the clutch to check it. It has left handed threads on it)
Posted on Apr 08, 2010
  • 95 Answers
SOURCE: My Stihl Farm Boss 029 leaks gas when I run it.
It could be the fuel tank vent is missing.try looking up your model number at ereplacementparts.com.It will show a diagram of whats where and the part you might need.
Posted on Mar 07, 2011
I just got a Stihl 029 Super and the bar oil is leaking out the bottom. There is some going on the chain but a majority of it is dripping from the bottom. Any sugestions before i swallow my pride and take it to a dealer???
Posted on Jul 30, 2011
I have an stihl 029 super chain saw that the spark plug won't stay in it. What parts do I need to fix it?
If the threads are crossed, stripped or loose, you need to take it to an engineering place and have a 'helicoil insert' fitted, this is a new steel insert that is tapped and threaded into the head after the hole has been enlarged a little.
helicoil insert Google Search
Dec 12, 2016 | Stihl Garden
Engin parts for 029 super stihl chain saw
perhaps a STIHL dealer can assist you .
Dec 09, 2016 | Cars & Trucks
How remove fuel tank from a stihl 029 wood boss ?
stihl have a range of pdf version workshop manuals for their equipment
go google and enter details and download the manual for your machine
Jun 18, 2016 | Stihl Garden
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Gas vent hose is missing. What goes on end of replacement hose?
A lot of Stihl have a tiny tiny tiny allen headed set screw just screwed into the open end of the vent. Some have a fancy deal with many descriptions. Try a set screw ran in flush with the opening of the vent tubing. Keep it clean and venting, because an unvented tank will not allow fuel to be drawn into the cylinder.
Mar 15, 2015 | Stihl 029 Chainsaws
What is the fuel line routing on a Stihl FS 44?
Bigger (inner)of the two hoses is the supply to the carby ,the smaller hose (outer) fuel return from carby to tank.
Aug 26, 2012 | Stihl String Trimmer Brushcutter Service...
My Stihl Farm Boss 029 leaks gas when I run it. The saw runs fine. It appears as though theres a small hose missing from the top of the gas tank. Looks like there should be hose going somewhere but its...
Mar 02, 2011 | Garden
Stihl 029 super oiler is not working
Mar 08, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Got a Stihl 029 super, fresh gas ,vapor coming from carb. wont idle,help
Dec 31, 2009 | Garden
If it's the clear vent hose that connects to the tank on the left side, that's it. There is a brass plug inside the hose that meters outside air in the tank to regulate the pressure. The hose connects to the tank nipple, done.
Nov 19, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
