Question about Linksys Wireless-G WRT54G Router
I have a at&t modem trying to hook up linksys wrt54g2 wireless to it but cant figure out how to help please
  • Linksys Master
  • 32,281 Answers
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Feb 12, 2012
tech curly
  • 298 Answers
SOURCE: Linksys wireless adapter and linksys wrt54g2 router not seeing each other
its possible that the wireless card does not have the correct wireless settings.
Open the linksys wireless monitor on your wife's laptop.
Go to the profiles tab, highlight the default SSID then click on edit at the bottom. It will search for the wireless network, from the list of networks that it will show you, click the name of your wireless network, in if the network is secured you will be ask to put in your network key. Then click connect. Then it will say that you profile was successfully configured. then click connect to network. It will take you back back to the screen where you saw no association to the access point, check if you will now get a new message. On that same screen click the more info button at the upper left hand side. Check the IP address it should be 192.168.1.x. If you have that IP then you can test if you will be albe to get online.
if you still have any problem just reply to this post.
Posted on May 21, 2008
tech curly
  • 298 Answers
SOURCE: LInksys wireless router stopped working
Who is your internet service provider and what is the model no. and brand of your modem?
Posted on Jun 01, 2008
Bat1956
  • 585 Answers
SOURCE: setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 28, 2008
  • 4 Answers
SOURCE: I have a cisco linksys wrt54g2 v1 that I have
Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
Posted on Oct 24, 2009
Testimonial: "Thanks a bunch!! I was about to pull my hair out! You are the Man!!"
SOURCE: can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Posted on Dec 19, 2009
Cant connect to linksys router wrt54g2 v1.5...able to recognize home connection not able to connect to internet...dsl modem works properly...I have the password and user info for the modem...please help...
Most modern DSL modems operate as a NAT. If you plug directly into the modem and get an IP address that starts with 192.168, the modem is the NAT. Instead of connecting the modem to the WAN port on the router, connect it to one of the LAN ports.
To see what your IP address is, assuming Windows, open a command window. At the command prompt, type "ipconfig" (without the quotes) and hit Enter. It'll return your computer's IP address.
The simplest way to test this is to simply connect the modem to the #1 LAN port, using the supplied ethernet cable. Power the modem and router down. Fire up the modem. When it's active, fire up the router. Now connect and see what happens.
Jun 18, 2011 | Linksys WRT54G2 Wireless Router
Wrt54g2 ver.1 driver
There are NO drivers as such for a router, it is simply accessed via a Web browser, by typing in the address and login & password of the router, and setting it up from there. Manual & setup link how to below. belkashop.com.ua/products_files/WRT54G2_V10_EN.pdf
Mar 08, 2010 | Linksys WRT54G2 Wireless Router
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
I have a cisco linksys wrt54g2 v1 that I have hooked up to my verizon dsl modem. My computer says I am connected but it wont let me get on the internet. If I plug the ethernet cable from the modem to my...
Oct 24, 2009 | Linksys Wireless-G WRT54G Router
Connecting 2 pc's to westel modem
No you cant.. But good router I preffer Linksys wrt54G2. Should just be able to plug ethernet from modem to WAN on wrt54g2.
Sep 16, 2009 | Westell Wirespeed LiteLine 6110 Modem
Had to install new Hughesnet modem.
the huges modem plugs into the router. there should be a network cable plug that is seperate from the others on the back of the router. should say line or lan.
Jun 19, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Setup linksys wrt54g2 broadband router with prolink h9200 modem
Dec 27, 2008 | Linksys Wireless-G WRT54G Router
Cannot connect to the internet with my laptop
To connect to the router wirelessly using a Windows XP, right click on the wireless network connection icon on the lower right corner of the screen and choose view available wireless networks. Select your existing network and click on the connect button. If you are using Vista, go to network and sharing center of your control panel then select connect to a network. If you still having problems, please provide details of the problem like your Internet service provider and if there are already other computers online with your WRT54G2.
Jul 11, 2008 | Linksys Ultra RangePlus Wireless Routr...
Linksys Wireless-G WRT54G Router Logo
51 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
