Question about HP LaserJet P4015 Printer
P4015 exit jams with duplexer
Does not jam without duplexer
IB4G2008
  • 3587 Answers
SOURCE: HP LaserJet 4700DN Duplexer Jams
hmmm..check the paper for riffling(with fingers before placing in tray)..and the rollers can get slippery, after a period of time...
check your computer warranty for FREE here
Posted on Feb 22, 2008
SOURCE: Duplex Path, paper late jam
Can you save that one document as a pdf and print it?
Posted on Mar 31, 2008
leroyal
  • 2120 Answers
SOURCE: P3005n prints one sided fine, but jams in fuser on duplex
Lower the rear door ALL THE WAY DOWN past the 2 stops
Remove the 2 screws, pull off rear cover
Remove the small left rear cover and small right cover
Unplug the 2 small plugs on the right side.
Remove wires from white clip.
Remove large white plug on big circuit board
Remove 2 screws and pull out fuser
Look for a switch knocked off
Posted on Feb 14, 2009
  • 685 Answers
SOURCE: paper jam on hpc7280 printer noise from duplexer area NO PAPER JAM
Follow the instructions in this video. If you follow those instructions and still get the message, you may need to replace your printer or the rear door.
Posted on Jun 17, 2009
  • 105 Answers
SOURCE: Our HP Color Laser Jet 4700 dn frequently gives an
There is either a small piece of paper in your paper input section or you have a paper sensor going bad.
Posted on Nov 20, 2009
Iam getting the duplex paper jam error 371 each time i try to print . how do imake the error go. i dont use the duplex at all.
See page 75 of the attached user manual on how to remove a duplex paper jam. If you can't find a paper jam in the duplexer, simply remove the duplex assembly (power off the printer, then power on) and see if that resolves your issue.
(The printer will operate just fine without the duplex assy. installed)
Okidata C9650 User Manual
Sep 12, 2012 | Oki Printing Solutions C9650 Led Printer
Duplex jam 0 - check inside
hey just open the back door of your printer remove the jammed papper...den resart your printer n then print...Robert
Jan 05, 2010 | Dell 1815dn All-In-One Laser Printer
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Oki C9300 - paper keeps jamming in the 2 same places, reads either 383 paper jam or non paper sense error. All drums and tonners are new, paper is loaded.
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Oct 20, 2008 | Office Equipment & Supplies
T642 Paper Jam and Check paper stock jamming.
You need to change the paper type when using card stock, plain etc.
As for the paper jams; you need to check the exit sensor at the exit door, also if you have a duplex, 2-3 drawer you also need to check for jams.
Sep 08, 2008 | Lexmark T642 Laser Printer
Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Jan 23, 2008 | Xerox Phaser 7300DN Laser Printer
Paper Jam E54
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Nov 17, 2007 | Toshiba e-Studio65 Copier
HP LaserJet P4015 Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
