My kyocera km-2560 showing me c0640,please i need help.
  • 43 Answers
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Posted on Mar 02, 2008
IB4G2008
  • 3587 Answers
SOURCE: c-7 980 error code
ok..so you have two kyoceras with issues...let's address the error code first..do you have the users manual handy? It's usually in there. I'll check my reference on that, and also look into the waste toner bottle..
Posted on May 08, 2008
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
SOURCE: Service Manual for KM-1815 Kyocera Copier
all km manuals are available from New Jersey Copy
contact tony@newjerseycopy for all mita service and op mans
Posted on Jan 05, 2009
digitalcopie
  • 77 Answers
SOURCE: Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
Posted on Feb 18, 2009
Iam able to do a system print out but cannot do a copy
if you can not scan a copy from doc feed or glass may have a bad hard drive. will pull a error code C0640
Jun 21, 2014 | Kyocera Mita KM-3035 All-In-One Laser...
Km error code cfb31
firmware update is the only solution sorry about that but you can contact me if you really need the firmware +2560702155632
Dec 10, 2013 | Kyocera Copystar CS-2560 Black and White...
What is code error c0640 on kyocera km-2560
Corrupted data. clear the all the jobs from the que. restart the machine and this will fix. if not means bad hard drive.
Feb 11, 2012 | Kyocera Office Equipment & Supplies
Kyocera km-2560 c6400 zero cross signal error
To reset this error hit 10871087 this will put the unit in Maint. Mode. Then press 906 then press start.Execute will appear on the screen press it. Either the machine will turn off by itself or it will say on the screen to turn the unit off then on using the power switch on the side of the unit. If the code comes back after all this either the fixing unit or the power supply are bad.
Hope this helps.
Jun 27, 2011 | Kyocera Copystar CS-2560 Black and White...
Error c6000 kyocera km-2560
THERES A PRINTER OR A PAPPER JAM GET AIR IN CAN BLOW OUT IF CARDLIDGE REPLACE WITH NEW.
Feb 15, 2011 | Kyocera Copystar CS-2560 Black and White...
I have Kyocera km-2050 it coming error for call for services error code -C6400
press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Dec 05, 2010 | Kyocera CS-2550 Black and White Copier
Hi We're using Kyocera Mita KM-2560. Unfortunately someone in our office was able to change login settings through device internal web interface. When I turn on the machine it asks username and password....
try Admin on both username and password ( A caps).
Also try 3000 on both or 6000 on both. try to select the system menu button and type the username and password there.
Jul 20, 2017 | Kyocera Office Equipment & Supplies
I have mita km3035 but when is working shows an error 0630 and then stop.so i have to turn it off and wait few seconds and turn it back on to continue help me please
Sorry to hear this.
A C0640 Is a DMA Problem:
• DMA transmission of compressed, decompressed, rotated, relocated or blanked-out image data does not complete within the specified period of time.
Solution:
Defective main PCB.
More than likely you will need to replace the main board.
Hope this helps.
Aug 21, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
66 people viewed this question
jasbo
jasbo
