Question about Dryers
How do I open dryer to replace drum slides on a speed queen gas dryer model no. adg30rgs111tw01
Model no. adg30rgs111two1
  • 1028 Answers
SOURCE: Speed Queen gas dryer won't heat
probably not most likely bad coils on gas valve the 2 black dohickys with wires
Posted on Jul 23, 2008
TheMobilian
  • 8220 Answers
SOURCE: my speed queen dryer doesn't tumble
One of your wheels is probably locked up or your glides may be binding to the felt base. e2a7a49.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 10, 2009
greg_margo
  • 1959 Answers
SOURCE: My speed queen gas dryer drum will not tumble what
Most likely the drive belt is broken. If you pop off the panel at the bottom of the machine, you will probably find a broken belt on the inside. The belt itself isn't very expensive and the overall repair is around $75 to have a repairman out.
Posted on Apr 15, 2009
canbruce75
  • 1776 Answers
SOURCE: LPG kit for Speed Queen 30XG gas dryer
You should be able to convert it over. Check out the link that I am providing. It's information on the conversion process and what it entails. Hope this helped and best wishes.
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
Posted on Sep 06, 2009
heatman101
  • 43501 Answers
SOURCE: Dryer does not heat. Electric ignition does not "spark" lighting
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
What's your problem?My older Speed Queen gas dryer is making squealing noiseses
I work on commercial units ,and this sounds like a trunnion bearing, or drum has come loose
1 loose trunnion bolt -easy fix
2 bearings - call experience repair
Jul 16, 2017 | Speed Queen Washing Machines
What's your problem?Squealing Speed Queen dryer
The drum of the dryer has a belt that turns the drum while in operation. These belts are not hard to replace and if your old belt is still attached you can visually see how it is positioned on the drum. However, there are also at least three rollers that carry the drum allowing it to rotate as it is being turned by the belt. These rollers are also not that expensive and are relatively easy to replace. Since the machine is 20 years old you may experience some problems finding the parts (maybe not)> You can check with the company via the internet and find out. Just give them the model number and a description of the part. The pulley that is attached to the shaft of the motor that drives the belt that turns the drum could also be worn out. Replacing the pulley on a machine that old can be trying but not impossible. If you have a technician check out and make repairs on these potential problems it probably cost well over $180 but if you have any mechanical ability you can probably do the job yourself if you can locate the parts. Just make sure the machine is unplugged from an electrical source before removing the back and the rest is just work.
Dec 12, 2011 | Speed Queen Dryers
I DONT HAVE A GAS DRYER AND I JUST BOUGHT A HEATER ELEMENT JUST DON'T KNOW WHERE TO PUT IT ON MY SPEED QUEEN DRYER
If does vary by model of SpeedQueen dryer,but typically the heat element fit in the bottom or the rear plate the supports the drum..reply with model number and i will tell you where yours goes.
GENE
Sep 04, 2011 | Speed Queen AES68AWF Gas Dryers
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Sep 02, 2010 | Speed Queen AGS28AWF Gas Dryer
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
Sounds like something is loose inside the dry drum
Unplug dryer!!
There should be 2 5/16th screws on the bottom panel in front. Then there are 2 more on bottom of top panel. Take off wires to door switch. Take off 4 screws to front bulkhead. Pull it off. Note how belt goes on. Take it off and pull drum.
I would first rotate drum by hand and see where noise is coming from. If inside one of the baffles in drum, you can easily lossen up screws to remove baffle to get things out.
Jan 10, 2010 | Speed Queen AES28AWF Electric Dryer
My speed queen gas dryer drum will not tumble what do you think is wrong?
Apr 15, 2009 | Speed Queen AGS28AWF Gas Dryer
Speed queen commerical dryer
try replacing the gas valve coils. they are cheap
Jul 25, 2008 | Speed Queen CGS68AWF Gas Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
