Question about Garden
23hp kiwasaki cold start winds to long before starting
    Sergeant:
  • 316 Answers
Hello sir, mower will not start or run,runs only when primming, does it have good spark,good compression,or only runs on full choke, are you getting fuel to the engine if not try this,your fuel pump or your carb. is clogged up here is what you can do for a simple repair for the carb,you can remove the air filter and assy, empty fuel tank and clean out tank and line,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bow, and fresh gas,you should be good to go,hope this helps.,thank you.~~
Posted on Feb 20, 2012
Starts Great cold, Will not start when hot
Usually it's the opposite lol...but this is a normal issue sometimes when too much oil is added into the oil cavity. Then what happens is the oil gets hot and thins out creeping past the piston rings, next time you go to start it, it's basically too oiled up,wet... combustion suffers.. check the oil level, spray carburetor cleaner into the plug and the carburetor if possible. Restart the mower and let it burn off the excess oil. If this until has a thermostat, double check to make sure that it's not closing off and choking out the air flow.
Oct 05, 2015 | Toro TimeCutter SS5060 50" 23HP Kawasaki...
Why my yanmardiesel tractor has trouble starting when cold
this should have a cold start system on it , which is a ether start , most of the newer things have them easy to install , the fuel is harder to start than gas ,
Dec 26, 2014 | Garden
Problems with cold start, when running everything ok
Cold temperatures do a number on batteries
Have your battery checked and go from there
Mar 08, 2014 | Cars & Trucks
2004 Toyota Sienna LE engine screeches upon cold starting
Are you saying the serpentine belt is screeching after the engine starts, or the starter is screeching when you are cranking the engine ?
Jan 29, 2013 | 2004 Toyota Sienna
One cylinder not firing
check compression hot and cold both cylinders there should be at most a 5% difference in compression values. if compression is low in the one in question than be paired to rebuild the unit.
Aug 08, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Hooked battery up backwards. No response now. Did this affect the electrical system?
hi there osudadof3
most likley that you blew the main fuse , replace the fuse with same rating and see what happens but be carefull enven though the unit may start and run - it may have blown the regulator / rectifier ( through a a direct short to ground ) and or damaged the ignition armature(s)
as they do not like d/c current through the primary windings ( they burn / blow out )
did the machine turn over ? or did it blow fuse straight away when key turned on ?
let me know what you find
cheers pauly46
May 06, 2011 | Husqvarna 23HP VTwin Hydrostatic 48" Cut...
Kawasaki fh680v 23hp will not start at random. Coils are good, fuel pump, filters air and fuel, plugs and battery are all good. Valves are adjusted correctly and one head gasket has been replaced. It will...
Check solenoid on the back of carb! I just had a similar issue with the same motor, would start rite up but had no power! new fuel pump coils, plugs ect I found the ground wire going to the coils were zip tied to manifold and rubbed through on the underside of wire never saw it 2 days later ripped it apart again and bingo found it taped it fixed problem.
Aug 12, 2010 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Starts when cold but once it is warm and is shut off it won't
Hi!
Looking at your brief description can I guess that when warm the starter turns slowly? as if a flat battery?
If this is so then the starter windings and armature are possibly cooked??
Have you recently tried cranking the engine too much? or with a poorly charged battery?
When cranking the starter gets very warm and if not left to cool after 5 seconds of cranking can cook the wiring/armature internals of starter.
When your engine is cold the Windings/armature are too so will turn easier, but when warm all internals are expanded so more drain and heat! then causing the starter to revolve slowly taking a lot of power from engine and ignition circuitry.
This can also be caused from trying to start a vehicle with low battery, Volts go down Amps go up cooking/frying the winding/armature.
I am suggesting this as all I have to go on from the description STARTS COLD BUT ONCE IT IS WARM???? I hope this helps,
If it does please remember to press FixYa button as I have taken a lot of time to post the response.
Good Luck!
Paul 'W'
Onyer~EDSon(:0)~[><U.K.
Jan 12, 2009 | 1993 GMC Safari
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
