Question about RCA F36444 36" TV
Blank screen, power light clicks on and
Screen is completely blank but the power light clicks on an off making a very faint on/off sound. Set is two years old and worked perfectly just hours before the problem started. I have tried plugging an unplugging. I removed the surge protector and plugged it directly into wall. All other compenents work fine on plug and surge protector. Removed DVD, VCR and antenna--no, don't have cable but get all major channels with rabbit ears :). Anyway, unhooked everything and tried TV on all alone with no luck. I have a technician scheduled to come look at it in three days for $75 (I cannot lift or transport unit).
  • 1 more comment
  • Jane Legion Aug 09, 2006
    Does this sound like something that will be reasonable to fix? Or something major that will make repair costs exceed the value of the set?
  • Jane Legion Aug 15, 2006
    Turned out to be a bad high voltage transformer. It cost $293 to repair. The technician charged $75 each for two trips each to the house, $50 for the part and the remaining $93 was labor/tax.
  • fsu1971 Jun 26, 2008
    I am having the same problem, is this something I can change? Do I have to get a repair person?(Which is hard to find around here!)
    President:
  • 3,130 Answers
This sounds like the common problem for this set. A bad connection in the sweep section or a bad flyback and a bad horizontal output transistor. Good Luck.
Posted on Aug 09, 2006
  • Larry  Dillon
    Larry Dillon Aug 10, 2006
    I would say in the hood of 250 to 400 would be high end.
Rca lcd tv power surge lighting
The power supply is a likely place to find what's causing the problem
Jul 11, 2013 | RCA Televison & Video
Blank Screen
If it has sound, then its back-light has failed which is a service engineers work but may also be related to a screen fault in which case a new set is needed as cost of repair makes it not worth it.
If no sound then dare I say worse and mostly if more than 2 years old, not worth it, sad to say as parts do not linger very long other than major brand names most are generic badges on economy sets.
Hope this helps..........
Nov 24, 2017 | Vizio vm190xvt 19 in. TV
I have a 46" Samsung LCD tv that won't turn on. When I press the power button you can hear the chime sound it usually makes and you can hear the relay click and the screen flashes quickly then goes bl
sounds like you have a back light problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flash light on the screen. If you see the faint picture on the screen, you have a back light problem. You could either have a shorted inverter that is pulling down the 24vdc line, a blown CCFL back lamp, a high voltage short (arcing) from one of the inverter outputs, or a faulty 24vdc power supply
Dec 09, 2012 | Televison & Video
My hp pavilion screen went blank, what would be the problem?
Is the screen completely blank or can you see a very, very faint image on the screen if you turn it to the light?if so, it could be the backlight at fault on your screen.This could be the TFT panel at fault or the screen inverter board that makes the backlight wor
Oct 13, 2009 | HP Computers & Internet
My Toshiba Satellite L305-S5877 will sometimes go into a "sleep" type mode randomly and the screen goes almost completely blank. I can just see what is on the screen very faintly. I checked and...
You have to disable the hibernation mode. Sounds like this is the problem. Go to Start - Control Panel - Performance and Maintenance - Power Options - click on Hibernate tab and uncheck where it says Enable Hibernation. This should fix the problem. Cheers
Oct 02, 2009 | Toshiba Satellite L305-S5877 Notebook
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
My screen turns faint...
maybe try going to settings and click on battery and display and fix the light setting u have set on there if thats not helping then try calliing t-mobile
Jul 24, 2008 | T-Mobile Sidekick ID Cellular Phone
Blank screen, cannot get menu to display, but sound works
Does the lcd screen have a glow to it ? Or is it really dim if u get real close to screen u can see images moving ?
it it has a glow to it you panel lighting is fine but you control board is bad. If you have a dark screen and see faint images you panel back lighting is out u can check the power with a meter at the connection to inverter board on panel.
May 03, 2008 | Televison & Video
Goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Dec 30, 2007 | NEC PlasmaSync 42MP3 42 in. Television
RCA F36444 36" TV Logo
136 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
