Question about Toshiba Satellite A105 Notebook
Trying to replace the little round lithium backup battery but it is held with clips. How do I remove the battery
The little round lithium backup battery is held down with a clip. I can't get the battery out to replace it. How do I undo the clip so I can replace that battery without breaking the clip
  • Toshiba Master
  • 32,281 Answers
Press the clip with a sharp point on the inside edge towards the outside edge and the battery will pop up. You may need to lever the battery up at the same time.
Posted on Feb 12, 2012
Where is the coin battery on motherboard located?
what do you mean by the coin battery??
or do you mean the small round lithium battery?
if its the lithium battery it will be a very small round silver battery just a little bit bigger than a watch battery.
why do you want to find it any way???
Nov 05, 2016 | Computers & Internet
Remove ths fog lamps on a 2012 GMC Sierra SLT
Its simple the fog lights are held in with several round clips that have 4 little tabs. Take a deep 10 or 11mm socket ,place it over the round clip, then push out on the light.
Jan 03, 2015 | GMC Cars & Trucks
How do I change the battery on a Windesign Racing ex3018 watch?
You need a tiny flat screwdriver. Remove the 4 screws on the stainless steel back. There is a little spring clip holding the battery in. Use the tiny screwdriver to unlatch one end of the spring clip. Replace the battery (3 volt lithium Maxell CR2025 or equivalent) positive side up. Re-latch the clip and then replace the back, being careful not to cross thread the screws and secure the back well to keep water out.
Jul 11, 2013 | Watches
I am trying to replace the little round lithium backup battery in my laptop but it is help with a clip that I can't remove. I don't want to break it so how do I replace it
Feb 11, 2012 | Toshiba Computers & Internet
I put new lithium triple aaa batteries in my TI-83. Nothing happened . days later it turned on worked for a little while then stopped. would it help to change the round lithium battery? Do you know what...
The button cell backup battery keeps the memory electrically refreshed when the calculator is turned OFF. The necessary power for regular use is supplied by the 4 AAA batteries (main power). That nothing happened when you put in a fresh set of (expensive) lithium batteries may be due to the screen being too dim to see anything.
If the calculator displays RAM CLEARED each time it is turned on, it may be due to a depleted backup battery. The battery model number is CR1616 or CR1620. On my TI84PLUS the backup battery is of type 303 (Sony) or SR44SW (Maxell).
Sep 05, 2010 | Texas Instruments TI-83 Plus Calculator
HAD BATTERY FAILURE MESSAGE - NOW COMPUTER WILL NOT EVEN TURN ON??
The battery is a small round silver lithium battery found on the motherboard, it keeps the memory of the bios and the settings from being lost when the computer is turned off, using a very small voltage. If the battery fails the bios then looses all its settings, normally returning the computer to default factory settings and asking you to reset every time the pc is booted, in your your case it would be worth unpluging from the mains and taking the side cover of the pc, find the battery and completly remove it there is just a little spring clip holding it in place, so just use your finger nail press the silver clip backwards towards the plastic rin of the battery holder and the battery should pop upwards allowing you to remove it, then try to boot the pc, if the same thing happens, you will have to change the battery. You can pick up batteries at your local pc store probably for nothing if u ask nicely, insert the new battery and then boot the mechine again. post back and tell me what happens.
Jan 27, 2010 | eMachines T5048 PC Desktop
How do you get the battery out of the case of a Casio AMW320RD-2AV? The back unscews and I can see the #370 battery held by some sort of blue band, but how to release it?
Under that blue band is the metal clip (contact). Take the tweezers and pull a little that blue band off, then find out where the contact is clipped on and undo it by pulling legs apart.. Buy exactley the same battery and replace it. Do make sure you wonn't plase the new battery other way round.
Rate, please.
Jul 22, 2009 | Casio Watches
I have ibm t23 or 2647
Try removing the backup battery for the bios and the main battery. The bios battery is a small little lithium battery usually located under the memory access panel. Killing the bios backup power causes it to lose its memory and go back to default, AKA No More Password. If this does not work you must find the security eeprom located somewhere on the motherboard and short pin 3 to pin 6 with a paper clip and power up. This will set the security eeprom back to manufacturing mode and once again, no more password.
In the most extreme cases the eeprom actually has to be replaced, this only occurs on very high end units. If you have any questions feel free to contact me. Good luck.
George
Ps. you can find the location of the eeprom easy just google for your model laptops security eprom.
Jul 16, 2008 | Acer Aspire 5100 Notebook
Blakck screen
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 20, 2008 | Texas Instruments TI-83 Plus Calculator
Black screen
If one of these solutions doesnt work you will most likely need to purchase a new calculator.
Batteries:
Hope that helps!
Jan 12, 2008 | Texas Instruments TI-83 Plus Calculator
Toshiba Satellite A105 Notebook Logo
77 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
