Question about Refrigerators
Bosch Fridge Freezer KGU3102GB, Moved from house to garage. Now working intermittantly?
fridgetech
  • 473 Answers
SOURCE: Daewoo Fridge Freezer not getting cold
Possible problems are a bad evaporator fan motor or a defrost problem. If the back panel in the freezer is frosted up then it is a defrost problem. If no frost listen for the fan in the freezer. If you don't hear it then it may be the problem. Not circulating the cold air.
Posted on Oct 05, 2007
SOURCE: Bosch Fridge freezer will not work
This is a Solution posted by a guy called Sandy Small in october 2005 and believe or not it works
Repair to Bosch fridge freezer KGV3104GB
This MIGHT be the same as yours!
Detach top panel above fridge door and "hinge" it down towards you attached to its connecting wires. See if the connector on the right has a thick black wire (nearest the fridge) and two brown wires. The faulty fridge temp. sensor can be shorted out by connecting the black wire to the brown wire next to it. I managed this by bridging the corresponding points on the PCB with a blob of solder. My fridge freezer works OK now on the freezer sensor. Hope this works with yours!
Sandy
Posted on Sep 29, 2008
  • 2920 Answers
SOURCE: fridge quit cooling after i moved it
did you tilt it when you moved it and then when u got it in place plug it in? if so youve got compressor problems, anytime you tilt a fridge you have to let it set for several hours to allow the oil to get back to the compressor or you ruin the compressor
Posted on Jan 01, 2009
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
  • 363 Answers
SOURCE: suspected broken fan prevents top fridge section cooling down
Very good diagnosis and conclusion. That price for the motor is about right. I think you will not have any truble with the ciculation after you install the motor.
Posted on Jul 29, 2009
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
Rcd tripping
Either the start relay in the compressor is grounding electrically or the defrost heater is (most likely start relay). To replace this yourself is difficult as it requires technical knowledge. If you are located in California, bay area I could help you personally
Apr 21, 2014 | GE Profile PSW26P Stainless Steel Side by...
Fridge freezer tripping rcd
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Apr 21, 2014 | Refrigerators
Hi i have a fridgemaster fridge freezer and it was moved from mil house on Wednesday. It now will not freeze although it does get some ice at the back of freezer but then defrosts itself. The fridge will...
Have you made sure that that the water connection to the ice-maker is secure and without leaks or stopped up (kinks) in some way? I would suggest that you unplug it for bout 30 min., then plug it back in. See what happens about after 45 minutes. If it was moved, you want to make sure you have tapped into the main water line. It doesn't just magically happen. Sometimes the simplest things can cause immedite problems.
Jan 18, 2018 | Siemens Bosch Neff Integrated Fridge...
We recently moved to a house with a Bosch KGV28V01GB fridge freezer outside but it doesn't seem to be working. Its plugged in and the light comes on when the door is opened. The switch is set to ON but...
Good day,
Refrigerators are designed for indoor use only. The lowest temperature they will perform normally is 55 degrees.
As the temperature drops below that it degades to the point of not working at all.
P.S. If you move it inside, give it a 24 hour warm up period. The oil in the compressor will be too thick, and can even ruin itself trying.
Jan 01, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Suspected broken fan prevents top fridge section cooling down
Jul 29, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Jul 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
