Question about NetGear WGR614 Wireless Router
The modem has a crack on it could this effect it working properly or interfer with the signal?
  • NetGear Master
  • 32,281 Answers
A cracked plastic case will not interfer with the wireless signal unless the wireless router has been dropped on the floor.
Posted on Feb 12, 2012
I am only getting error code 020100
  • This error code says that your DSI is not able to connect to the internet.
  • Move within 30 feet of your modem and make sure no phones or radios are interfering with your modem.
  • Also DSI will have trouble getting on the bet if you are on a hot spot because when other PC's drawing from the modem can effect the DSI's ability to connect to the modem.
  • Most of the time just moving closer and making sure no walls separate you and the modem fixes the problem.
Tony
May 30, 2011 | Nintendo DSi Matte Blue Console
MY MODEM (SB4200) IS REALLY SLOW
open the internet explorer on the addresss bar put 192.168.100.1 then go to hack add on file adress file d11_m_speedtierextreme2_c01.cm
then on ip server file put 68.87.68.35 the press change id then unplug the modem then plug it back the speed should be back
Apr 29, 2010 | Arris SURFboard SB4200 Modem
Internet connection cutting out intermitently
1. check the current firmware updates
2. verify no other devices next the the router interfering with the signal i.e. cell phones, cordless phone, microwaves, TV sets.
3. check your router or cable modem for connection during time the wireless is dropping connectivity.
Apr 25, 2010 | D-Link DIR-615 Router
My Motorola Modem Mstatea
When the DSL light turns red it indicates that the modem has no internet signal.
So please check if the cables are connected properly
Also ensure that there is a proper signal to your premises without any interference
This is called intermittent connection
If the DSL light turns red it indicates that there is a problem with the cables connected or the DSL line
Please check your DSL connection with ISP
There is on another reason that the modem might have gone bad.
If all the above steps are executed and if this issue still persists replace the modem
Jan 28, 2010 | AT&T High Speed DSL Modem
During a thunderstorm we heard a crack and believe our computer got hit - everything seems to be fine, except we cannot connect to the internet checked jacks and cords, but they are fine, could it be the...
If it's a broadband modem (cable or dsl) reboot the modem. Also look for diagnostic lights on the modem, they will give an indication if the modem is working properly. If after rebooting the modem, you are still getting trouble lights, contact the isp provider and explain your modem is no longer working. Most isp's replace faulty modems at no charge.
Jul 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Siemens Speedstreem 4100 Modem Not Working
Try restarting the modem by either turning off the power button, or plugging out the modem power.
If the internet still frequently disconnects, it is most likely your ISP's (internet service provider) problem. Call them up with this issue, and they should either re-activate your internet for you, or give you a replacement modem for free.
Hope this helps, please rate and leave a comment ^_^
Jun 18, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
No Wireless Signal on modem(no green light)
just reset your modem at the back button. and check your antenna if properly installed.
May 24, 2009 | Westell Wirespeed VersaLink...
Phone trying to connect to the base but cannot
You possibly have a Mhz signal conflict with another appliance in your home or in another 'apartment' if you live in a complex.  If not, there is a similar or identical signal (with the same Mhz listed on your phone in your home from another appliance trying to use the same frequency) interfering, like a router or router/modem for wireless internet.  I had a similar problem when I had a wireless home phone not connecting to the base and would not call, stay connected or code right with the base.  I used a Linksys router to connect to an AT&T modem and nothing matched. Until I got AT&T to upgrade me to their "2wire" router/modem combination built in and my wireless internet problem was solved.  But, the V-Tech phone lost it's ability to connect or operate properly after that, even with a new battery.  We scrapped the wireless base and phone and now stay wired, also an option.
May 24, 2009 | Vtech Cordless 6041 Phone
2-wire wireless box
Did you unplugg the modem or did you switched off the power from the back?
For the filters, did you use the right filter for the modem?
and another for your modem
Aug 05, 2008 | Computers & Internet
Linksey Modem and router wireless
This will depend on the store you bought it from. To alleviate the low signal, however, you can try a few things. How far is your computer from the router? Have you tried multiple machines, and do all get low signal? It's possible that other routers in the area are interfering, and if that's the case you can change the channel from the common default of 11 to something else.
May 13, 2008 | Linksys Wireless-G WRT54G Router
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
